voltage
My Ride: 525nsport
been told my alternator is OVER CHARGING guy took a plug off it saying its to do with smart charge? with wire on it was 15volts wire off its 14 volts he says alternator fkd but if its still charging how can it be fkd my freind says its possibility of a module instead of alternator anyone shed light on this good thing is no more warning lights appear on the dash
Engine: N54
Sorry dude... not enough info here to make any helpful ideas.
You need error codes or something more helpful. 14 some volts when engine running is normal.
My Ride: 525nsport
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
My Ride: 525nsport
From what you have described, one cannot definitely say that the voltage regulator is faulty. Nothing wrong with 15 volts charging the battery, depending on its state and type. And 14 volts resting is also normal. Sometimes "a little knowledge is a dangerous thing".
My Ride: 525nsport
My Ride: 525nsport
jprovence
May 9, 2009 03:16 PM
nigxdoof
13
Jan 15, 2009 12:07 AM
nigxdoof
Jan 5, 2009 10:58 PM
nigxdoof
Jan 11, 2008 01:51 PM
