Voice Command Question
I have a 2008 528i and I have successfully created a phonebook and I have used voice command to dial numbers and names. However, I haven't been able to use the voice command for other functions such as the CD player, etc. When I spoke Help to it, it responded with phone commands but no other commands. I have read the voice command section several times in the manual, but I can't figure out why I can only use phone voice commands.
Any ideas are appreciated.
Thanks,
Thanks,
My Ride: E90 M3
Model Year: 2011
Thanks,
Thanks,
Thanks,
Thanks,
Thanks,
Thanks,
Originally Posted by Shamu' post='502793' date='Dec 4 2007, 11:29 PM
I have the exact same issue...in fact it still won't recognize name-based dialing, only numbers. I'm bringing my car in for a check at my dealership for this, and other minor issues I've come across in the 2008 528i.
Originally Posted by JSpira' post='502795' date='Dec 4 2007, 09:37 PM
If you mean speech-to-text, this is available if your car has a CCC (as I just posted above in this thread). If you don't, you will be asking about a feature you simply don't have because you opted for the low version of the computer and not the high version.
Thanks,
I assumed the named dial would work with my uploaded address book, but it doesn't. You have to create a voice phone book in order to use voice command to dial numbers by name. The instructions for this are found on page 207 in the owners manual. Did you try that yet?
Originally Posted by Todd in AZ' post='503170' date='Dec 5 2007, 06:27 PM
I don't have navigation in my car and I don't know what CCC stands for but from the sounds of things it looks like I may not have this feature? I can only use the voice command for phone related commands, but nothing else.
Thanks,
Thanks,
This is why you don?t have voice command capability. It comes only with the CCC.
aqualibrium
07-21-2015 03:11 AM
jeffandjaimie
07-08-2015 05:48 PM
