Vibration at highway speeds
Take it to someone who knows what they are doing with balancing. I made the mistake of using tire kingdom. They balanced brand new cont's three times at one shop and twice at another. Still road like a dump truck! Caled conti and complained. They suggested another small private shop. Took car there and they did a great job. No more balance problems. Hub centric and making sure the wheels are put on correctly. Hopefully you weren't wasting your time and money on children who work in most of the chain tire shops.
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
OK what the hell, as I was coming home from work today, the right side tire/rim was making a noise as if I was going over the lane changing reflectors! It only makes the noise on speeds 40mph+ and the faster i go the worst it gets.. any idea here ???
My Ride: Gray 05 545i Oem M-Tech kit 20" agio s nine wheels 20x10.5 rear 20x9 in front
I had the same problem with my 545i I did everything to try to get rid of the vibration and it ended up being my control arm bushings i replaced them and the vibration went away
Last time i took it in for service my indi said the control arms needed to be replaced .. so I guess that's what it is huh
bestofthebest
03-28-2016 02:47 PM
