URGENT help needed with smg
my friend just bought a used 5.45 with smg. unfortunately the car did not come with the manual :thumbsdown:
can anyone help clarify if the smg can be put in "park"?
when left in neutral, a warning will come on saying that it is in neutral
Thank in advance for the hlp
My Ride: G30 M550i
Model Year: 2018
On any manual trasmission, including an SMG, there is no "park" -- instead, you just park the car in a gear. Most people will put it in first gear if they're parking on an uphill and reverse if they're parking on a downhill. Either one can be used (first is usually smartest) on a flat surface.
On the SMG, if you are stopped in gear and you open the door, the car will shift itself into neutral so you need to park it, put it in gear, then switch off the motor before opening any doors.
UNFORTUNATELY !?!?!?!?!?!
Listened, Rudy ?
Originally Posted by Rudy' post='444868' date='Jul 8 2007, 08:12 PM
I think he means owner's manual, not "old-fashioned manual" (as in the transmission type...)
Ops, misunderstanding, sorry
My Ride: G30 M550i
Model Year: 2018
By the way, if you need a copy of the manual, you can download it from here:
http://www.e60.net/information/
wow thank you so much rudy. hope u enjoy your new car with the new SAT.
and btw, yeah i meant the owner's manual and not the "manual" transmission.
sorry for the misunderstanding. thanx once again
socale39
09-05-2023 08:30 AM
Mihainede85
03-11-2015 09:45 PM
