Update on Performance Woes from 20.01.00
#101
Or start a BEEN KILLED thread LOL SL65 AMG! I WANT THAT CAR!
[/quote]
Me too. I see we both are very flexible. Z06's, for whatever, as long as it is very fast.
#102
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
On your horsepower issue you must remember that the GT2 derives horsepower from a number of inputs.It is strictly a calculation.Your time to speed is the only the only one that is changing in this equation,as your time increases your horsepower readings will decrease.It can't account for faulty shifts but just see's a slower time therfore you must be developing less horsepower.
Going to do the Z06 now.
[/quote]
I have read your post#66 again and the only fact not clear to me is how you developed the torque decrease.May be the answer was contained in the attachment you sent to me in the pm.However using the speeds you calculated for 6375 rpm I have calculated the following:
M1-33.629 mph @ 6375 rpm
M2-59.923 mph @ 6375 rpm
33.629/59.923=.5612
.5612X6375=3578 rpm
The rpm at the m1 to m2 shift point is 3578 rpm.the torque peak of a 545 is 3600 rpm.This is almost the perfect shift point(the torque peak).
There is a formula that has been around for many years for calculating horsepower from speed vs time.I am sure this is how the GT2 calculates horsepower.It has no way to actually measure horsepower.
I looked at your post#90 again after you updated.I think it more clearly shows the largest times loses are at the shift points.
#103
33.629/59.923=.5612
.5612X6375=3578 rpm
33.629/59.923=.5612
.5612X6375=3578 rpm
(a) the RPM after the first to second shift is 6,500 X 2.34 / 4.17 = 3,648, and
(b) the RPM after the second to third shift is 6,500 X 1.52 / 2.34 = 4,222.
The RPM after the first shift is close to the maximum torque point of 3,600 RPM. But, note that RPM after the second shift, 4,222, is not as close to 3,600 RPM. Nevertheless, these shift points are theoretically optimal because the decreases in torque when shifting from first to second and second to third are smaller than the decreases that occur given any other choice of shift points. At least, these are the implications of the formulation I am using for determing optimal shift points--taken from Lawlor's Auto Math Handbook. Under this formulation, it is not necessarily optimal to shift so that the resulting RPM is at the torque maximum.
So, we don't want the Step to shift at 6,375. If it is doing so, then the torque decrease are too large. And, we may have two factors affecting times and HP's: (1) the Step shifting too soon and (2) the Step shifting lazily.
Two more things. Remember that an actual HP decrease or a problem with DSC/DTC also may be occurring since I can barely spin my wheels any more--even with brake torquing..
Finally, how does your car feel? I hope it is AOK.
#104
JUst tested 2 times tonite..70 degrees.. Shifted to M1 DSC off... I got the wheels to spin in both runs easily and then the car shifted to second seems the rpm hitted the rev limiter and shifted? i also did a little more inspirited driving and the car feels quicker and smoother wonder if I got lucky... on thing I noticed is that my mpg is not as good as before (well not because of the hard driving) , i filled up last nite, driving locally and can not get more than 15.3mpg? while before i was able to get easily to 17 or 18.. i guess is a trade off with peformance
#105
Whay not get a GT2, and join the test thread? Your car seems fast, and you could provide some great data on 550i's.
#106
It dawns on me that the following JPEG might help. It is a graph of the 545i's HP/torque curve--with my conversions to ft. lbs. for pertinent points and identification of these points. Some of the points and converted values will be hard to read--probably. Not all points and converted values I used are identified on the graph--as I recall. Also, I did not spend much time ensuring perfect accuracy when drawing lines, identifying intersections, etc.; small errors in what I was doing would not matter.
#108
Originally Posted by Znod' post='234627' date='Feb 4 2006, 10:53 AM
grogan. Do you still want to time to distance info?
#109
Yes Znod I think it might be helpful in determining if times are influenced more by loss of power or slow shifts.
[/quote]
OK, it will take me a little time to get it done. Today is busy, and I have to find some of my original data. How is your car?????? Great, I hope.
[/quote]
#110
My Ride: MY RIDE is DA real .-) HAMANN 5 aka BLACK MAMBA born on 16/06/2005/delivered on 05/08/2005 as following:
530dA (steptronic), Black II (JET), leather Dakota auburn black, mapple trim, head-up display, dynamic drive, active steering, adaptive xenon headlights (auto levelling) with headlight washers, alarm, comfort seats with massage function, advanced A/C, big compartment armrest, aux-in, MP3, Logic 7, Radio PRO, CD in-dash+cd changer, power rear sunshades, rear airbags, park distance control, auto dimming folding mirrors, smoking package, shiny shadow line (individual), fold down rear seats, ski bag, sport suspension, run flats on �116-style� rims (Good Year NCT5+), cup holders, debadged, fire extinguishers, additional permanent power outlet, BMW coat hanger, trunk release button (installed by Hobi), GPS tracking device and a big thx 2 Iceman.
Mods done:
� Authentic HAMANN FRONT APRON Including ellipsoid fog lights Item-No.: 10 060 110
� Authentic HAMANN REAR SPOILER Item-No.: 10 060 130,
� Authentic HAMANN HAMANN ALUMINIUM PEDALS For cars with manual gearbox Item-No.: 80 099 100 81,00 For cars with automatic transmission Item-No.: 80 099 120
� Authentic HAMANN FOOT REST In aluminium For left-hand drive vehicles Item No. : 80 099 122
� Authentic HAMANN HAND-BRAKE LEVER In aluminium For left- and right-hand drive cars Item No. : 80 099 216
� Authentic HAMANN Idrive of alu (sorry this is the only one in the World) but you can have it in carbon fiber ,
� Authentic HAMANN EXCLUSIVE FLOORMAT SET In black with HAMANN logo in silver For left-hand drive cars Item-No. : 80 060 120 For right-hand drive cars Item-No. : 80 060
� Authentic HAMANN COVER FOR OIL FILLER CAP In aluminium Item-No.: 80 099 117
� Authentic HAMANN SPORT REAR MUFFLER 4 TAILPIPES Sport rear muffler with four round stainless-steel tailpipes ( � 76mm ) Item-No.: 50 060 111
� Authentic HAMANN new add-on for M pack rear with diffusor for quad pipes -AVAILABLE NOW (http://forums.e60.net/index.php?act=ST&f=22&t=30630&st=0#entry332409)
� ///M steering wheel w Pegasus logo (this will be also changed to three spoke sports)
� ///M pack rear
� HAMANN ECU upgrade 265 HP 608 Nm.
most improtant:
�real and working like a charm forumsbuy real LED tails and PIAA 4700k fogs!!! for HAMANN full front apron you need H3
� CustomAngels, Angel Eyes Brighter than stocks 10X, WHITE & (REd for shows).
� Authentic HAMANN LIGHT-ALLOY WHEELS DESIGN EDITION RACE 20"
Ultra-light forged 3-pieced light-alloy wheel, Cross-spoke-design,Spider in black, titanium, screwing,polished flange
DIMENSIONS : 9.0 J x 20 FA Item No.: 91 207 315
10.5 J x 20 only RA Item No.: 91 207 625
Recommended 20" Complete Wheel Set DESIGN EDITION RACE I went with most aggressive Combination A.10 FA 9.0 J x 20 / RA 10.5 J x 20 with tires: FA 245/30 ZR 20 / RA 285/25 ZR 20
� Authentic HAMANN LOWERING KIT 4 progressive sport springs Lowering by approx. 40 mm FA, 20 mm RA Item-No.: 20 060 125
� Authentic HAMANN TIRE - PRESSURE CHECK SENSOR SYSTEM
� Authentic HAMANN SIDE SILLS Item-No.: 10 060 120
� Authentic HAMANN REAL CF ROOF SPOLIER Item-No.: 10 060 235
� Authentic HAMANN AIRBAG SPORT STEERING WHEEL 3-SPOKE Three-spoke design w their SMG paddles (For assembly O.E. airbag in exchange)
� Authentic HAMANN sports mirrors (all functions)
!!!!!!!!!!!!!!!!!!! and of course !!!!!!!!!!!!!!!!!
E60.net Clings
Still to do list;-):
� Our Hobi's camera system from : ww.switchchange.com).
� Individual leather interior (auburn+auburn alcantara)... and drive with sheer drivin' pleasure ... until 2009/2010 F10 comes or E60 possibly a 540d V8 diesel early in 2009 badly juiced!
sorry guys let me ask a stupid question as you are 90% testing US do you think that CIP 20+ would also slow down our "diesel" cars ??? I am curious as I am before my update should do or not? OK maybe you can just guess, but better not knowing THX!
Hey Don, I learned more from this thread than ever thx 2 all.
