UK (Scotland) Rear Tyres
Old Jan 21, 2008 | 04:14 AM
e60scotland's Avatar
My Ride: 525d M Sport in Carbon Black
More specific to UK owners, I called this morning to my local dealership, I was looking for a simple quotation, 'two rear tyres to fit the 172 (19') rims', Ok so maybe i should have had the tyre sizes, the answer was basically 'oh there are to many combinations, you will have to come back with the exact sizing' fair enough.
Ok so putting aside sizing for now, is there any reason I can't purchase from another tyre supplier? more specifically do the TPM sensors have to be replaced when having new tyres fitted ?
I'm figuring anything up to ?300/tyre for my rears but would be happy if someone in the UK can point me to a good supplier/fitter.
Thanks in advance for any feedback.
Old Jan 21, 2008 | 04:44 AM
MarcsOnFire's Avatar
My Ride: 535d M-Sport '06 Plate - Carbon Black - Black Leather - Pro Sat Nav - Logic 7 - HUD - Bluetooth - Privacy Glass - 172M 19" Alloys - Heated Seats - PDC - Adaptive Headlights - Extended Voice Control - Paintshield Extended - M5 Boot Finisher - Bright White LED Internal Lighting - Dension Gateway 500 Ipod/USB/Aux Integration
Hi,
I always use E-Tyres for my tyres.
They come out to you and fit the tyres there and then. I've found them to be pretty much the cheapest out there and the fitters are always professional and friendly.
Hopefully there'll be a fitter in your area.
Marc
Old Jan 21, 2008 | 04:51 AM
guy's Avatar
guy
where in scotland r u from?
Old Jan 21, 2008 | 05:09 AM
I'll Give etyres a try thanks.
Stirling
Old Jan 21, 2008 | 05:15 AM
keith84_uk's Avatar
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED) Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Try this one:
http://www.valuetyres.co.uk/
search 275/30/19
It can be choose to fit it in your local fitting centre, less than ?197/each for Toyo T1-R fitted
Keith
Old Jan 21, 2008 | 05:24 AM
colejl's Avatar
There's only one OEM size for 19" rears on the E60.... <sigh>
Anyway, I've used mytyres before - 275/30/19's are about ?230 each (Conti's), delivered. Then find a local trusted fitter, should cost you no more than ?20/wheel...
AFAIK all the UK models use the ABS based flat tyre monitor, so nothing special to do there...
Old Jan 21, 2008 | 07:11 AM
Palmo's Avatar
My Ride: E60 525d M-Sport Saloon M57N2 3.0d LCI EXTERIOR: Jet Black, ///M-Aerodynamic Bodystyling, ///M-Rear Spoiler, De-badged, Gradual Tint Windscreen, ///M-Double Spoke 172M 19" Alloy Wheels (with non-run flats & space saver spare wheel) & ///M-Sports Suspension; INTERIOR: ///M-Steering Wheel, Black Dakota Leather Heated Sports Seats with Electric Lumbar Supports, Brushed Aluminium Interior Trim & Anthracite Headlining.
How's things? Not seen you on the board recently?
I too need to replace my rear tyres - same as yours - Conti 2's, 275/30/19. Luckily, my father is in the motor-trade and so I can get a pair (as a favour) for ?408 (?204 each) inc VAT, fitted & balanced at a local tyre specialist he deals with.
The best other current deal I have seen is Kwik-Fit (I know not a likely place) as they have a deal where buying 2 currently attracts a 15% discount (4 attracts a 25% discount) until the end of the month (January). Price I was quoted was ?255 inc VAT x 2 = ?510 -15% = ?433.50 (or ?216.75 each), fitted & balanced.
Interestingly (and quite outrageous to be honest) I got a quote from my BMW dealer (Williams Manchester) and was quoted ?323.07 inc VAT x 2 = ?646.14, fitted & balanced for exactely the same tyres! That's a whopping ?212.64 (or ?106.32 per tyre) dearer than Kwik-Fit! I did double check all the details were correct and even the guy on the phone admitted 'they don't sell many because of the pricing not being competative'.
My car has now done 18.5K miles. The frustrating part for me is that the centres are worn to the wear-bands, while both outer edges on both rear tyres have around 3mm left. I think this maybe down to a faulty local garage airline gauge which I think may read 6 - 7 PSI over, and so I have been driving around with my tyres over inflated so to speak virtually since new (I always check them weekly at the same place (old habbits die hard and all that.....). I asked on this board out of interest if this is a common wear trait with this tyre / wheel combo but didn't really get a definitive answer. My fronts by contrast (and with using the same local garage airline) have worn much better with an even 5mm or so left across all the tyre on both.
How have yours worn out of interest and with how many miles?
Edited to add that there is nothing special with regards the TPMS as it doesn't use sensors in the wheels on our model, just the ABS sensor to monitor tyre rotation speeds as colejl says. You can check this by looking at your tyres valves, they should be standard rubber ones NOT metal types (which I believe use sensors placed in the rims which are very expensive).
Old Jan 21, 2008 | 10:43 AM
colejl's Avatar
That's a stonking deal!!!!
Just make sure whoever does the tyre swap actually cares about the (expensive) alloys they are mounted to...
Old Jan 21, 2008 | 11:52 AM
Palmo's Avatar
I am dreading having them changed for that reason. My dad is going to speak with owner to make sure one of the best guy's fit these for me. My dad's company spends a fair bit with them each month.
Old Jan 21, 2008 | 01:34 PM
colejl's Avatar
At least they're not taking runflats off and on. They are a $%&! to fit...
