Transmission&Will not start
Hi new here 2005 545i the other week I went to start my car and Up came all these errors "gear can be engaged without depressing the brake" DTC, ABS. Now it will not start either no crank no noise no nothing took it to my mechanic he found nothing recently put new solenoids in and fluid about 5 months ago because it was stuck in third gear got that fixed now this HELP!!!!!!!!!?????????
My Ride: BMW 550I BLK
Engine: N62
Engine: N62
I was having a some of the same issues in my 2007 550i v8's of course. Bmw named everything in the book from battery to shifter issues to selanoid to camshaft sensors and vanos. It turned out being the ivm module it's a lil box with fuses that controls the electricals. Look up the ivm module. On another note I had a 2004 550i that wouldn't start and that turned out to be an overload of coins in the ash tray by the shifter. A coin slid down in. The shifter area and was blocking. Needle nose pliers fixed that.
Interesting it seems like we are having similar issues. I have a 2005 545i, and I get some of the same errors and an occasional jump into third gear where it wont shift up or down. I will be driving along at 50 and " BLING " I'm in third gear with errors flashing.
But my starting issue comes and goes. It will start fine and then the next time it will just click when i press the brake and turn the key. But give it a few minutes and she'll start again. I am trying to fix the actual issue (perhaps the IVM module?) but try to disconnect your battery and hook it back up, it seems to reset the electronics and she starts fine for a while.
Engine: N62
Engine: N62
Surprisingly the dealership and it cost $105.00 I thought it would be a crazy price. But after I looked it up you can get them for under a hundred online. Now my steering rack.. it's been bad for a while now. I was gonna get one from the junk yard but you never know if the car was hit from the front. Lots on ebay but I'm gonna get mine from Detroit axel they have them rebuilt. The dealership cost $2200 and I sprung a oil leak, white smoke out of the exhaust when sitting in traffic at idle need a valve stem seals job so I'm gonna get that plus might as well get the seal done at the alternator and buy motor mounts because everything will be out of the bay. Plus my indy guy said if I get the rack and pinion he will toss it in free. He's charging me 3k for the valve stem seals job and he said since he's already gonna be pulling stuff out he will do the rest for $200. Oh the life of a v8 bmw. I've already had to change my radiator fan top hoses and that radiator fluid box. What next????
How about that. Yea man if this IVM fixes my electronics issue I will feel much better but I have a small coolant leak i need to investigate. My car has 164k miles so I imagine I will have to be replacing some seals and the like soon. I hope to be able to do it myself- does it require taking the engine out completely? Are these sorts of things something I have to worry about before I actually spring an oil leak?
I just want to get this car in shape but so far besides regular maintenance I have only been fixing things retroactively or after a problem presents itself. I am learning as i go
Thanks again!
Thanks again!
Engine: N62
Thanks again!
Thanks again!
