Transmission Replaced 2006 525i e60 Automatic
My Ride: 2007 BMW 525i E60 Automatic Sedan
1st time BMW owner of a 2006 525i E60 Automatic Sedan.Buying the car which was needing a transmission replacement, I ended up getting the car very cheap. I found a very low mileage trans from a 2007 525i E60. 5mths younger on the build date then mine. My built 12/06, New car/trans build 05/07, same series/model 525i e60 automatic, everything is the same except colour & build, 5mths differance. Any other car manufacturer this wouldn't be a problem(ford,gmh,toyota) no problem. But for BMWs, this would be a problem l later found out!!! HAHAHA & ALL YOU GUYS ON THIS FORUM ALREADY KNOW WHAT HEADACHES BMW CARS DO TO YOU.!!! I'm just finding out know!! So afrer watching a few videos on utube/speaking to some 'experts' (we all know what that means) i was confident I could change the trans myself & a few hours later, the trans was replaced & working buetifully by me. All trans codes are gone, gearbox is changing with the engine & working just fine together...... Except for 1problem. When it's in 'P' BMWs have a 2ndl lock park system with a sensor attached to it which I had to disconnect to make the gear selections work because they made one change from the younger/new trans from my old one. Now when you put it in PARK & turn the car off, I getta idrive message saying 'make sure you've selected park before leaving the car' it's not even a code error. So I want to ask you guys out there, can I completely erase this message completely from the idrive so that it doesn't pop up anymore??? Just like taking the seatbelt warning sighn off your dashboard for example??? The trans is perfect & working buetifully except for this one message I get when I'm parked with the engine off & leaving the car. I get this message everytime. Can anyone help me or give me some advice out in bmw land?? Thanks in advance
Which brings me back to your question about the
mechatronics
did I/or should I have changed over the mechatronics from both gearboxes??? if I should have, then that would have been a problem that I wouldn't have had the confidence of doing myself. I would have to take it to a specialist which would have costed a fair bit of money. As I said, I fixed the problem my way and got the car back on the road and the whole car is just buetiful to drive. Considering how much I paid for the car and how much people are selling/buying the exact car that I have, if I sold it today, I would have made a $8,000- $10,000 profit. But the car is not 4 sale and it's not a massive problem to hear this message when I start/stop the car. I can live with it, but if I can erase this message completely from popping up on my idrive that would be great. I don't want to go back to the gearbox/gear selector if I can avoid it. It's just a stupid message I get that would be good if I can stop it somehow from popping up!!!
do I need to register the new gearbox the same as you register the battery?? Would that fix it?? Thanks for replying to my post Sean, if you can give me some more advice that would be great. Cheers
