Transmission Problems: solenoid/valve body replacement?
Old 07-12-2020, 10:21 AM
Probation Members
Ken Howorth's Avatar
My Ride: bmw
Default 2-1 downshift bump
Originally Posted by KyleB
Impossible. 6HP26 is only for V8 powered cars. It will not bolt up to an M54 block, which if you have an '04 or '05 525i or 530i, you have an M54 powered car.
Kylie, do you know what this maybe on 2004 bmw 530i e60 with zf6hp19z
Old 03-17-2021, 12:32 PM
Beemw_guy's Avatar
My Ride: 2008 bmw 550i sport
Originally Posted by m5-fan
I have a 550i with 6HP26. The transmission fault 4F89 sometimes 4F83. The sometimes symptom are:
When using normal D shift: when it at 40-50km/hour, the engine is at about 1200rpm and when try to speed up, the transmission is trying to kick down the shift and the fault generated at that time.
When I drive at DS or Sport mode, this symptom has less chance to happen. There is not fault generated in the above situation but, when it has a long uphill, the transmission seems lazy to click down the shift. Sometimes even when I change to manual shift mode, it does change gear when to shift down.
My question: I want to buy rebuilt Valve Body and all the necessary sleeve and seals to replace. Would it solve my problem? Is there anyway to determine if other part of the transmission is still healthy?
Thanks you so much
hey how did you make sure your bmw 550 had the 6HP26 transmission? Where can i check i am having similar problems with my transmission and i need a rebuilt valve body but have no idea where to get one. Thank you!!
Old 03-17-2021, 12:37 PM
Beemw_guy's Avatar
Originally Posted by tivinps
I had the same symptoms in my 545. In my case the problem was cause by worn-out seals in the tranny. I did a full overhaul of the tranny and replace the valve body with a rebuild unit.
Hey tivinps where did you get your rebuilt valve body? I am looking for one desperately please let me know thank you!
Old 03-17-2021, 03:29 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
You can send your original off to get it rebuilt. That way you don't have to pair it back up
Old 12-02-2021, 10:03 AM
Flguy76's Avatar
My Ride: 2004 BMW 530i
Model Year: 04
Engine: M54 3.0L
Originally Posted by gil_g
I thought so as well, at first. However this is a 2004 model, and the transmission that's currently in it is a 6HP26. So I went with what was there.
there's noway no 04 came with a 26, dude I got evey service book for the 04 530i from bmw and it didn't come with that. Those are on like 550"s .. you sir need to return it
Old 12-02-2021, 10:05 AM
Flguy76's Avatar
Model Year: 04
Engine: M54 3.0L
yeah the 19
tivinps
07-18-2018 07:28 AM
gmcclintock@hotmail.com
10
05-29-2017 10:56 PM
mjkempe2
01-11-2017 07:35 AM
5_series_T
03-01-2014 05:24 PM
kneemah
05-01-2012 10:33 AM
Quick Reply: Transmission Problems: solenoid/valve body replacement?
