Transmission problem Automatic gearbox 530d/535d
I have experienced the following problem with my E60 530d auto a number of times now and would like to find others with the same problem to see how common it is. If it appears to be a design flaw, me might be able to prompt ZF/BMW to thoroughly investigate the case and provide a solution!
Description of the problem:
The gearbox makes a nocie (to me it sounds like a pneumatic drill, but others have described it as a "weird" sound or a "slam"...), refuses to change gear and the car refuses to accelerate. After a short while, the car apparently gets in gear and takes off again.
When?
- I have only experienced the problem when driving in D-mode, not in DS
- It appears when hitting the accelerator quickly e.g. to bypass another car and not when accelerating more gently. This has made me believe that it might be a kick-down related phenomenon, but I have no "proof" for this.
How often?
It has happened 7 times to date, despite my efforts to avoid these hard accelerations in D-mode. I am worried that this might cause damage to the gearbox and thus i try to shift to DS before overtaking.
When?
How often?
Our gearbox did make some really bad sounds to, when the car was new.. It only happend when the gearbox went 2 gears down..
Example: Driving 80 km/h i 5 gear, and when I hit the accelrator pretty hard (not kick-down) the gearbox did shift from 5 th to 3 th gear, and did make a terrible sound... :thumbsdown:
After a while BMW installed a new gearbox for free, and the new gearbox is much better!
hmm - did that make any sense at all ?
When?
How often?
When?
How often?
[snapback]177294[/snapback]
Hi Oreo,
I am experiencing a similar problem where the automatic gearbox does not change the gears until very late and the engine revs up to 3500rpm. Is your problem fixed now? I have booked the car for service next week and the dealer has told me I need to leave the car with them for 2 days...
my car have also problems withe gearbox. but dealer changed for free and after that everything was fixed BUT....i upgrade software too and have some problems with gears...now i go in two dass for new CIP 19 and i hope it will be smoooothly gears...anyone have also problems with this????
now i have CIP 16.xx....
