transmission problem
This does not sound exactly like problem described but it is the only active service bulletin that is close as of now.
SI B 24 09 08
Automatic Transmission October 2008
Technical Service
SUBJECT
GWS - Transmission Jumps Back to Neutral
MODEL
E70 (X5 3.0i) with N52K and 6HP19TU from 12/06 up to 09/08
E70 (X5 4.8i) with N62TU and 6HP26TU from 12/06 up to 09/08
E60, E61 (528i, 535i) with N52K/N54 and 6HP19TU from 03/07 up to 09/08
E60 (550i) with N62TU and 6HP26TU from 03/07 up to 09/08
SITUATION
The customer may complain that intermittently, after selecting the drive or reverse gears, the transmission jumps back to neutral.
Both displays (in the Kombi and on the GWS) are switching from D (or R) to N at the same time.
No faults are stored in either the EGS transmission control module or in the GWS shifter.
CAUSE
GWS software error
SOLUTION
On a customer complaint basis only, check the vehicle's integration level.
If the integration level is:
On E60, E61 vehicles ? E060-08-03-550 or lower
On E70 vehicles - E070-08-05-525 or lower
Reprogram and recode the complete vehicle with a current Progman version (V31.1, or higher). The target integration levels are E060-08-09-520 or E070-08-09-520, respectively, for E60/E61 and E70 vehicles.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty or the Certified Pre-Owned Program.
Defect Code:.. 25 16 06 66 00
Labor Operation:.............................. Labor Allowance:............................. Description:
61 00 801.......................................... 7 FRU............................................. Programming coding modules without CAS
61 00 811........................................... 8 FRU.............................................Pr ogramming coding modules including CAS
SI B 24 09 08
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
GWS software error
SOLUTION
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
Originally Posted by TMQ' post='727690' date='Nov 21 2008, 12:32 PM
As far as I know, the transmissions used in the 3 and 5 series are mostly the same, across similar engine models.
Of course, BMW is notorious for the auto transmission issues, including the infamous "no reverse" issue. I haven't heard too much about this, but will monitor this closely.
It will be helpful to others if you could provide more specifics on your transmission failure. at least it's still within warranty.
Best regards.
SI B 24 09 08
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
GWS software error
SOLUTION
SI B 24 09 08
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
GWS software error
SOLUTION
Is the 31.2 a solution to this problem?
My Ride: 2008 Space Gray 550i, Light Poplar Wood, Anthracite Head Liner, Sport Package, Sport Automatic Transmission, Cold Weather Package, Front Ventilated Comfort Seats in Black Nasca Leather, NAV, HUD, Active Steering, Comfort Access, Night Vision, Lane Deviation Warning, Active Cruise Control, Heated Rear Seats, Folding Rear Seats, Power Shade w/ Rear Side-Shades, Rear Air Bags, Logic 7, HD Radio, Sirius Satellite Radio, iPod/USB Adapter. Car in BMW Body Shop, estimated completion 01/24/07.
I don't have these problems per se with my SAT. However, if you do not engage the brakes slightly, you cannot go from P to D or the converse. I sometimes find that a little irritating, knowing however why the did it. That's not what you're complaining about, right?
Cal
Cal
Originally Posted by 08E60' post='725387' date='Nov 19 2008, 02:39 PM
I have been having problem on my transmission. I have had a hard time shifting from Park to Reverse. Not just on cold engine. It doesn't happen all the time, but I will say about 50% of the time it happens. Since I can't go from P to R, I had to go from P to D and then to R. Anyone else is experiencing the same problem? I don't know if it's just a problem with the sport tranny or the same thing with the auto tranny.
Dealer replaced "shifter switch". Came back about 3-4 mos later. Replaced the shifter switch again.
Its been fine for 4 mos now.
fyi
Have the same problem intermittently as well (from P>R, or D>R). Figured I was not pushing the shift knob up hard enough or too fast. Still happens sometimes when I take my time and push up hard. Glad I've got some fast reflexes for the brake pedal. Figured I'd wait til January for my 12 month service. Need to report this problem, hard brake pedal with some starts, and hopefully get the software update to fix the "turbo lag".
