Topping up engine oil on 530d
Just checked the dipstick, and its slightly below the halfway mark between max and min. So will probably top up soon.
Please can anyone advise what is recommended engine oil to use.
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
Nobody know ??
My Ride: Oct 2007: 525d SE Auto, Space Grey, Black Leather, Visibility Pack, Luxury Pack, Media Pack, Rear Air Bags, Space Saver Spare, Comfort Access, Auto Dim mirror + Ext folding, Through Load System, All round heated seats, Extended interior light pack, DAB, Logic 7, USB Interface and HUD.
Originally Posted by Gudge' post='573869' date='May 4 2008, 02:14 PM
Nobody know ??
Which actually means a few different types are OK. I have a 1L bottle of Castrol Turbo Edge 0-30W in the boot, which says it meets LL04. A search on LL04 will give quite a few hits. too.
I was always told to wait for IDrive to tell me to top up, even so I check the IDrive Oil level and actual dipstick too. SO far, 10,000 miles since new and no top-up required. Showing 2 bars on IDrive.
Originally Posted by rjc' post='573875' date='May 4 2008, 01:43 PM
BMW LongLife-04
Originally Posted by Gudge' post='573876' date='May 4 2008, 02:45 PM
Where on the I Drive does it tell you the engine oil level ?? Mine is a Dec 2004 build. Thanks.
Press the MENU button
Press the controller to bring up the 'i' menu
Turn the controller to 'Info Sources' and press the controller
Turn the controller until "Service" is selected
In there should be the "Check Oil Level", under service requirements.
It only works when the engine is running,.
Should be in the mobility bit of your handbook, if it was missing, there is a UK handbook as a pdf in the information bit from the homepage of E60.net
Just seen this on ebay. I know SLX has been replaced by Edge, but can someone confirm I can use this oil.
1 LITRE CASTROL SLX LL04 POWERFLOW 0W 30 BMW ENGINE OIL Item number: 270234087724
Castrol (BP) are the BMW recommend lubricants - Dont think they would risk putting BMW longlife 04 on a bottle and it not to be true. Both previous diesel bmw (2004) and my current one also use SLX(or II), infact only the M series cars use a different oil Castrol TRX ?? I think down to higher stressed parts and different bearings.
For you info my local Costco sell this Castrol edge 0w30 in a pack of 3x 1 litre bottles for roughly the same price as 1 litre from dealer.. it say it replaces the castrol SLX range. My wifes VW GTI uses this exact oil as well vw 504 spec.
PS be careful of ebay and oil whats actually in the bottle - it could be anything motorsaver 5.99 chip oil grundge etc..
MAE60D
MAE60D
Originally Posted by Gudge' post='574689' date='May 5 2008, 10:19 PM
Ok, I know I need LL04 for my 530d.
mantraguy
03-09-2015 02:56 AM
