TIRE PRESSURE
My Ride: 2006 550 SMG
I have a 2006 550 with sports package, bridgestone run-flats, anyone know what the correct cold-tire pressure is for these tires?
Banned
[/quote]
Look on the sticker on the driver's B pillar.
[/quote]
Yes and check the pressures once a month.
There has been some indications that the tires (espesially the RF's)
do not keep the pressure.
[/quote]
My Ride: 2010 750Li M sport
The manual also quotes it, but I don't recall. On the 550 they suggest different pressure for 4 people or less versus 4 people and luggage...higher pressure with the heavier load. I think light load up to 100 mph is 29 lbs front and 33 lbs rear. They recommend even higher pressure for over 100 mph. After reading it I remember thinking it was so much more complicated than that of my e39, which I think juist had 1 pressure indicated. Just went and checked the door. It shows 30 front 35 rear, while the manual reflects what I noted above. So, go figure. I guess whatever you do, keep the fronts a little less than the rear if you have the offset setup.
Also, don't forget to reset your tire pressure moniter in I-drive each and every time you adjust tire pressure.
One of the key advantages of BMW is their focus in maintaining a balanced height between front and rear axels (50% on each). Can anyone explain me why there is such a difference in recomended tire pressure for front and rear wheels?
The pillar is supposed to be more relevant (in the USA) than the manual as it is current as of build date where the manual is printed about ONCE a year.
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
![Post](https://5series.net/forums/images/icons/icon1.gif)
cheers
vern
