Timing Cover Gasket Torque Specs
Old Jan 17, 2013 | 06:52 PM
Beamed's Avatar
Default Timing Cover Gasket Torque Specs
Recently fell victim to the dreaded alternator seal leak on my 2005 545i after 125k miles. Decided to change the water pump and thermostat (still had original). Finished replacing the alternator seal and noticed leaks around the upper timing chain cover. Went ahead and replaced the gaskets on both sides, but I have a few questions.
What are the torque specs for the valve cover gaskets, upper timing chain cover gasket, and water pump?
Old Jan 18, 2013 | 05:19 AM
Margal's Avatar
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
I am trying to find this also. I do not want to buy Bentley manual just to get the torque specs. And I think that proper torque is important properly installing these gasket to prevent leaks again
Someone please post it in in-lb
Beamed, did you change the alternator bracket gasket yourself? Was it hard? And what would be your advice
Old Jan 18, 2013 | 01:17 PM
Beamed's Avatar
Anyone?
Old Jan 18, 2013 | 01:40 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Cylinder Head cover to cylinder head p113-41
M6 bots 10 Nm? 7 ft-lb
M7 bolts 15 Nm/ 11 ft-lb
M8 bolts 17 Nm/12.5 ft-lb
Cylinder head to timing cover 10 Nm/7.3 ft-lb p113-51
Coolant pump to engine block p170-18
M6 10 Nm/89 in-lb
M7 15 Nm/11 ft-lb
M8 22 Nm/16.2 ft-lb
Good luck!
Old Jan 18, 2013 | 04:52 PM
Margal's Avatar
Model Year: 2005
Is there any marking on those bolts. How do I know what size I am dealing with?
Are there three defferent size bolts used to secure valve caver, I though they are all the same?
theweeknd24
Jan 22, 2019 08:25 PM
ironb
DIY: Do It Yourself
May 1, 2015 05:31 AM
rlambotte
Apr 14, 2015 06:47 AM
TexaZ3
Apr 8, 2015 10:50 AM
thesalboy
Apr 8, 2015 09:13 AM
