Talk To Me About Diesel
#31
Originally Posted by blingo' post='281708' date='May 12 2006, 04:09 PM
A European spec 535d has oxidising catalysts and particle filters and will meet the emissions standards Stateside no problem when running on European diesel (you could eat your dinner off the inside of my tailpipes ). They need low sulphur fuel however as sulphur kills the cats, and so engines that will run on your current diesel fuel can't have these systems and wont meet current emissions.
Not sure about the amount of energy needed to provide a gallon of diesel/petrol, but my understanding was that it was a supply and demand issue. Every gallon of crude provides a certain percentage of each component, and the fraction that diesel comes out of is the one that drives demand. Petrol by comparison is surplus. If everyone drove a diesel we would be using more crude, more refinery capacity (and therefore energy), and someone would have to think of a new use for the petrol fraction or else dump it!
Politically, diesel will never be allowed to displace petrol, so the petrol/diesel debate (be thankful you don't have THAT in the States ) will continue for a good while yet.
I think you're right that it's the fractioning process that is probably the key here. As I understand it, the boiling point of the components that form petrol/gasoline is reached before that of the components that can comprise diesel fuels. It would seem logical that less energy would need to be applied to enable the extraction of the gasoline components compared to the higher temperatures that would need to be achieved to be able to reach the later fractions, including diesel. Thus, once you've extracted the gas component, part of what's left would or could be diesel (implying its the diesel that's the surplus, and that gasoline is an earlier fraction in contrast to ABC's suggestion a few posts back). Either way it does look like the low sulfur fuels are those that require more raw material to produce (there was an article in one of the papers here that made the same observation) and coupling that with the the lower boiling point of the gasoline components is where I was getting the support for the lower cost to produce and lower amount of raw material needed to manufacture a given unit of fuel. At the end of the day though I'm sure most of us here, and certainly me, are now getting out of our depth and supporting our arguments by deploying our Petrochemical Engineering degrees from the prestigious University of Google
#32
Unless we know numbers, all else is emotive rhetoric.
ABC
Oh yes, I was entirely upside down (OK wrong!!) in my distillation fractions.
#33
My Ride: 04 525DSE Auto Olivin
I thought the defractionating process was the same for most fuels with them drawing off the different grades/compounds at different levels in the tower i.e. the heavy diesel carbon chains are caught near the bottom and petrol drawn off further up the distillation stack. That way the crude is only processed once.
Oh yer I am a Civil Engineer and not a Chemical Engineer so my memory could be failing me.
#34
My Ride: E61 535d sport, Silver Grey/grey/maple.
20" Hartge Nova 7. Previously 19" staggered 172s
Originally Posted by aybeesea' post='281721' date='May 13 2006, 01:19 AM
Why would that be the case when (like for like) fuel economy (MPG;l/100km) is significantly improved when using diesel over using petrol?
For example:
For simplicity let's say that 10 gals of crude, among other things, produces 1 gal of petrol and 1 gal of derv.
A petrol car and a diesel car can therefore have a gallon each.
If both cars are diesel, to give each a gallon you would have to process 20 gals of crude (twice as much energy as processing 10), and throw away 2 gals of petrol.
Relative economy would have an effect of a few percent for sure but I was trying to make a bigger point.
#35
Interesting story about diesel from the crapper
http://www.nzherald.co.nz/section/story.cf...jectID=10381404
Marlborough-based Aquaflow Bionomic yesterday announced it had produced its first sample of bio-diesel fuel from algae in sewage ponds.
It is believed to be the world's first commercial production of bio-diesel from "wild" algae outside the laboratory - and the company expects to be producing at the rate of at least one million litres of the fuel each year from Blenheim by April.
jashy247
02-23-2021 05:50 PM
robfrey1
08-22-2015 09:57 AM
