Switching out a blown MPM module
Old Mar 6, 2023 | 03:46 AM
rkaen's Avatar
Probation Members
My Ride: bmw e60 530D
Default Switching out a blown MPM module
Good day everyone,
i’ve been looking for a used mpm module, but I can’t seem to find one with the exact number. Do everything need to be the same or what?
Old Mar 12, 2023 | 10:26 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Originally Posted by gman6262
Look up the part number in Realoem - that will give you the other part numbers for that module. The module needs the correct firmware for your build - which means you need to be careful with the application dates on the alternative numbers. You won't be able to use an older module than your build.
https://www.realoem.com/bmw/enUS/par...&q=61356939655
I thought MPMs were plug and play. The years do not matter. As long as it's one on the link you posted it will work. I've never had an issue at least.
Killaduce
Sep 17, 2021 10:01 PM
oggy
Jun 9, 2013 01:11 PM
holimar1
Bluetooth & Cell Phone Forum
Mar 15, 2013 03:58 PM
cookceramics
Sep 29, 2011 12:38 AM
