suspension getting harsher...
Old Oct 10, 2005 | 01:19 AM
Jeffs's Avatar
My Ride: 2003 X5 3.0----->gone 2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone 2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods... 2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
My ride is becoming harsher. Is it because the tires are gettin bald?? Or do I need to see my dealer? I hate seeing them because it takes a week to even get an appointment wi the service manager...
Old Oct 10, 2005 | 03:42 AM
Gray Dog's Avatar
My Ride: 2006 530xiT, Silver Gray, Automatic, Navigation, Heads Up Display; Premium Package, Comfort Seats, Logic 7 Sound System 2003 M3, Dakar Yellow, SMG
[snapback]182080[/snapback]
The tires could be the problem.
Old Oct 10, 2005 | 03:54 AM
FJPM's Avatar
My Ride: 535 D - to be delivered end Feb 2005 - color E08 - comfort seats - executive leather balck - 122 wheels - dynamic drive - active steering - pack luxe - tecnology pack - moon roof - 6CD player - hifi system - spare wheel - BT phone
The heating-cooling cycles make the tyre harsher when they get old
Old Oct 10, 2005 | 10:40 AM
Ralph-NL's Avatar
My Ride: '04 BMW E60 530d High Executive
What kind of suspension do you have? Normal or 'air' suspension
Old Oct 10, 2005 | 12:53 PM
Jeffs's Avatar
[snapback]182257[/snapback]
I have sport suspension...is there even an air suspension option in the 5?? I never knoew that
Old Oct 10, 2005 | 12:55 PM
allenman's Avatar
And why would your dealer have anything to do with replacing tires?
Get thee to a quality tire shoppe!
Old Oct 10, 2005 | 01:15 PM
znod's Avatar
Hi Jeffs:
Do you have the Dunlop run flats? If so, then maybe it is the Dunlops. If the wear in on the inside, then I'd go to your dealer and try to get them replaced. They will need to have less than 20K miles to be replaceable. Check out this thread and the one I refer to on its page 2.
Old Oct 10, 2005 | 03:37 PM
Hormazd's Avatar
Aside from the distinct possibility that your Dunlops are worn, you may have an Active suspension/dynamic drive problem. When cornering, dynamic drive raises the pressure to the struts to give us the flat cornering. This pressure is increased using the power steering pump. When operating optimally the pressure is released after the corner. In your case the pressure remains high.
I had this problem and after many days of diagnostics going back and forth between my deaker and BMWNA, they changed the power steering pump.
I first realized that I had this problem because I would hear a clunking noise when the car approached bumps at a certain angles. They determined that the noise went away when disconnecting the AS fuse. That is how they isolated the problem to the Active suspension.
Vman33
Mar 14, 2022 04:43 AM
subieworx
Sep 13, 2015 11:02 PM
bmwmonkey
Aug 17, 2015 10:34 AM
PelicanParts.com
Aug 4, 2015 01:34 PM
ArnottInc
Aug 3, 2015 12:42 PM
