Sunroof problem
Hi guys,
I was trying to close my sunroof in the morning, but the sunroof seems to be stucked when the outside
Temprature is cold. It was about 25 - 34 F. This happened 3 times in 2 weeks.
Is this normal guys?
Thanks,
Yoko.
Thanks,
Yoko.
Originally Posted by Rudy' post='499113' date='Nov 26 2007, 06:12 AM
What happens exactly? Does it not move at all? Does it stop moving before it reaches the closed position?
It worked fine when I tried to open it; but when I was trying to close it, it stucked.
It first moved until it touched the "rubber" around. and it just go away to the opposite direction (Open direction again).
Sorry, English is not my first language Rudy.
I have the video of it, but I don't know how to post a video in this forum.
Thanks,
Yoko.
My Ride: G30 M550i
Model Year: 2018
Take a look at the following .pdf instructions for initializing the sunroof:
http://forums.e60.net/index.php?autocom=ga...si&img=4517
I'm not sure if that will fix your problem but it's worth a try. If it doesn't work, then there may be something in the sunroof's track that needs adjusting or lubrication. (Something might be contracting in the cold temperatures and causing additional resistance when the roof slides...)
My Ride: 2008 535i, 6spd mtx, Monaco Blue w/Beige interior. Sport, Preimum, Logic 7/HD/I-Pod/USB, Nav sys, rear sunshade, HUD, PDC, Split seats,
I'd probably just keep it closed anyway - if it's that cold outside...
