Stutters at 1500-2000 RPM
Old 07-23-2023, 12:36 PM
  #31
Chrizplz's Avatar
My Ride: 520D facelift
Originally Posted by donpb
Are you throwing any sensor codes? I feel you may still have something intermittently failing or clogged. If SeaFoam helped a little, you may need to go through a couple more fueling cycles. Also, if you're using cheap fuel, it can be counterproductive to SeaFoam.
Sor my FB user got hacked had to make an separate acc. There is always something..
but yeeh I actually got 2 new codes. And they are all related to the DPF
I now have
4a2a particulate filter system (new)
452A info particulate filter system
480A DDE particulate filter system (new)
last one basically means my DPF is clogged up
Yeeh as mentioned, the fuel I’m using is from Statoil or shell usually. I don’t think they sell cheap fuel, sure doesn’t feel like it in my wallet
Old 07-31-2023, 03:23 AM
  #32
olliecampbell's Avatar
My Ride: '09 530d MSport Touring Manual
Originally Posted by Chrisplz
Now im just confused, when we startet our trip home it suddenly started acting up again. Like it’s almost choking even when we are driving now.
as soon as I unplug the MAF it’s driving fine, way slower acceleration but it’s driving nice. Which takes me away from the DPF.. So the question is, which sensors is communicating with the MAF 🤔 and effecting it like that
The MAF will also disable the EGR. I can't remember if you said you still have your EGR in place or not. But that could be the next test, pull and bung the vacuum line to the EGR.
Old 07-31-2023, 06:29 AM
  #33
Chrizplz's Avatar
ahh i see, well the EGR is still there. So that might be my new problem. So just pull out the vacuum hose for the EGR and put a zip tie on it? And test it?
Old 08-02-2023, 07:24 AM
  #34
Pliug the vacuum pipe with a small bolt or similar and then test.
You'll get an engine warning light after a couple of starts whilst the pipe is removed.
SkylineGT-R
07-22-2023 08:33 AM
bachirnassif
E39 Discussion
10-26-2014 09:06 AM
gimbli
E60 M5 Discussion
08-26-2014 05:59 AM
Extra
04-16-2009 02:06 AM
Quick Reply: Stutters at 1500-2000 RPM
