Strange SMG Behaviour
Old May 6, 2009 | 09:37 AM
Westcoast M5's Avatar
Unhappy
My 06 M5 (32,000km) SMG is acting up. When the car is cold (ie: sitting overnight) if I start it and then put it in gear and try to drive away right away, nothing happens, it just revs or pulls away slowly as if you were riding the clutch. If I let the car idle for about 30 seconds or more then select 1st gear the operation in normal. I suspect maybe a problem with the hydralic pump - weak or low on fluid?
I have searched on SMG pump replacement but having found an desciption of the symptoms leading up to a failure. The car has also started feeling a bit jerky on some shifts and sometime on take off the clutch feels a bit "juttery", but these symptoms are pretty mild and I have wondered if it's just my imagination playing tricks on me since I am now constantly aware and listen for it all the time.
Obviously I will have to take it in to the dealer but wondered if anyone had any thoughts/advice to arm myself before I go. Thanks.
Old May 6, 2009 | 11:04 AM
MBX5's Avatar
My Ride: 2005 545i SMG, Sapphire Black/Tan, Sport Package, Cold Weather Package, NAV, Comfort Seats, Satellite Radio, Premium Sound, Sunshades
Sounds like the pump. I had a similar thing happen several years ago and they replaced the pump and one other part (actuator?) that I can't recall. Fixed the issue completely and I've never had another problem.
Old May 6, 2009 | 12:13 PM
Thanks! I will post up the resolution once I get a chance to bring it in.
Old Jun 4, 2009 | 11:54 AM
Update: "Found reservoir for SMG hydralic unit leaking. Replaced washer for plug on reservoir. Top up fluid. Tested OK."
Glad it was a quick fix!
Mihainede85
Mar 26, 2023 07:49 PM
Jiawei Zhao
Oct 21, 2015 08:46 PM
bestofthebest
Oct 2, 2015 03:21 PM
phillc
Sep 28, 2015 12:11 AM
LILBZ3
Sep 27, 2015 08:06 PM
