Strange noise from steering?
Old 07-06-2009, 12:19 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
anyone know what this newer thicker power steering fluid is?
Old 07-06-2009, 12:50 PM
Stu535D's Avatar
My Ride: 2005 535d, M Sport,Carbon Black, DMS remap, 166 Gloss Black alloys with 12mm H&R spacers rear.
hi guys,
i've experienced the same problem on my 535d, BMW have issued a service memo regarding this and there are 3 fixes.
1) Replace the lubricant on the steering column for a thicker improved solution.
2) Fit a collar to the steering column preventing the movement of the splines which causes the noise
3) Fit a securing bolt to the column to prevent movement of splines.
As stated before this is a problem on all e60's which BMW is aware of and will fix under warranty!!!!!!!
Old 07-18-2009, 01:14 PM
arnirj's Avatar
I have that same promblem but it sounds like something is rubbing rubber, The sound doesen?t seem to start until I have been driving around for a few minutes and it?s getting worse.. Is this the same problem that you guys are talking about the steering fluid....
Old 07-18-2009, 02:23 PM
Krozi's Avatar
If its a groan, it might just be your brakes. To test this, put the car in Neutral and let your foot off the brake and turn the wheel. If the groan is gone, it's not the steering but the brakes
Old 07-18-2009, 05:05 PM
Mrsosoo's Avatar
My Ride: BMW 545i
ive got this as well, as do a lot of my friends with E60s, guess I should head to the dealer also
Old 07-18-2009, 07:16 PM
Banned
Diamond's Avatar
can someone post this service bulletin. I have this too kind of moderate-loud clicking sound whne turning the wheel either way to the extreme at a stand still or slow speeds-and the sesrvice manager said there were no bulletins regarding this issue-would be helpful if someone posted one so I could take it with me. thanks
Old 07-19-2009, 08:05 AM
theXman's Avatar
My Ride: 2004 530i
+1
Johnnywadd
09-03-2015 01:23 PM
stylinmike
09-01-2015 04:55 PM
Bounce
08-31-2015 10:04 AM
srogers535x
08-05-2015 08:48 AM
PelicanParts.com
08-04-2015 01:34 PM
Quick Reply: Strange noise from steering?
