Stereo Crackling
#31
I too still have the static. It usually occurs after the 2nd start of the day. Drive it to work in the morning -fine. Drive it to lunch -fine. Drive it back from lunch -STATIC. Goes away anywhere from 10 minutes to an hour. I usually just mute the radio and then check back on it every 5 minutes or so. Very annoying. The dealer has already replaced the MASK unit on this - has not resolved the problem. I'm guessing they're going to try the TCU next, which is what they first diagnosed the problem as.....
I've been waiting until my next oil change to bring the car in so I can knock my laundry list out in one visit (hopefully)....
Let me know what your dealer tells you please.
#32
Originally Posted by acribb' date='Mar 15 2005, 05:52 PM
I too still have the static.? It usually occurs after the 2nd start of the day.? Drive it to work in the morning -fine.? Drive it to lunch -fine.? Drive it back from lunch -STATIC.? Goes away anywhere from 10 minutes to an hour.? I usually just mute the radio and then check back on it every 5 minutes or so.? Very annoying.? The dealer has already replaced the MASK unit on this - has not resolved the problem.? I'm guessing they're going to try the TCU next, which is what they first diagnosed the problem as.....
[snapback]102066[/snapback]
#34
Originally Posted by T silver e60' date='Jul 28 2004, 05:34 PM
THERE IS A FIX!!
Insist to have the product replaced.? The cost of this product is $1,400 to $1,500 so the dealerships are really reluctant.? I had my car brought in under the same conditions explained above on 4 occasions and so my dealership finally caved in.
This new replacement part has been in my car for over 3 months and not a problem with any static.
[snapback]19341[/snapback]
#35
My Ride: E60
I'm still living with this. Dealer cannot fix it and they won't replace the entire computer.
I wish there was something more I could do. I hate all the crackling on AM and CD.
Ok, what is the part? It's the TCU isn't it? I believe the list on that item is $1400 or $1500? Does anyone out there who had static in their non-Logic 7 stereo system EVER get the problem resolved? Thanks, after living with this for 1 1/2 years, I think I deserve to have this fixed.....
Originally Posted by acribb' date='Jun 21 2005, 05:35 PM
[quote name='T silver e60' date='Jul 28 2004, 05:34 PM']THERE IS A FIX!!
[snapback]141724[/snapback]
[/quote]
#36
If its crackling sounds it may be one of two problems. First, it could be that one or more speakers are gone. There could be a tear at the soft area surrounding the cone. This would happen if you have blasted your system too loud.
The other cause could be that your amplifier/head unit connections may have come loose. Try driving into road humps or uneven road surfaces and if the crackling noises are consistant with the bumps, then it is surely the cause.
With a car like the E60, we jump to conclusions blaming the software too often. Can't blame anyone of us because the servicemen at the dealerships around the world are doing the same.
Just my two cents worth from past experiences.
#37
My Ride: 2005 545i (SMG)
Titanium Gray
Black Interior, Anthracite Trim
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
Do you have Logic 7? If you have Logic 7, the crackling is NOT a defect. It's just distortion from the processing. I get it all the time, because I use Logic 7 processing and listen to music loud... and the style of music I listen to requires a top-notch stereo to play it.... which, unfortunately, the Logic 7 is not.
You're just learning how crappy factory audio systems are.
The crackling is processing noise, or you're playing louder than the system's limits can comfortably allow.... nothing more.
If you are going to check the speakers, however.... be sure to check where the wires are glued to the inside of the speaker voice coil. inside a speaker, there will be 2 wires, and these wire are often glued to the speaker cone to prevent them from hitting the cone when it moves back & forth. Sometimes heavy use, and/or weather conditions cause the glue to unstick. Then the wires hit the spaker cone and make an awful buzzing noise. A little crazy glue can fix this problem.
But, honestly.... I think it's just processing noise.
#38
My Ride: E60
I do NOT have Logic 7.
(1) AM crackles / gets feedback with every spoken word at all volume levels.
(2) CD music crackles, shorts in and out, back and forth from one speaker to another at sporadic times at louder volumes (again it's not unreasonably TOO loud).
The first thing the dealer tried was to replace the speakers. Then they messed with some other connections. Then they changed some grounding thing. Then they blamed software and said to live with it. The speakers are NOT bad though. It's something else. I read that others have experienced this and the only thing that fixed the problem was replacing the entire TCU and my dealer won't do it.
Originally Posted by subterFUSE' date='Jun 30 2005, 09:43 AM
Do you have Logic 7?? If you have Logic 7, the crackling is NOT a defect.? It's just distortion from the processing.? I get it all the time, because I use Logic 7 processing and listen to music loud...? and the style of music I listen to requires a top-notch stereo to play it....? which, unfortunately, the Logic 7 is not.
The crackling is processing noise, or you're playing louder than the system's limits can comfortably allow....? nothing more.
If you are going to check the speakers, however....? be sure to check where the wires are glued to the inside of the speaker voice coil.? inside a speaker, there will be 2 wires, and these wire are often glued to the speaker cone to prevent them from hitting the cone when it moves back & forth.? Sometimes heavy use, and/or weather conditions cause the glue to unstick.? Then the wires hit the spaker cone and make an awful buzzing noise.? A little crazy glue can fix this problem.
But, honestly....? I think it's just processing noise.
[snapback]144621[/snapback]
#39
Titanium Gray
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
If it's not Logic 7, then it's not the processing then.
It just means the stereo is crap.
#40
I MAY HAVE AN ANSWER - I had the popping occuring, sounded like a small stone hitting the windshield, and happened more when the temp was higher (pm) than in the cooler mornings. Noticed mostly on satelite radio.
Took it in and the dealer stated in short time it was the stereo amplifier. They had to order for replacement.
Note I do have logic 7 so that dealer who made that statement is nuts.
