steering wheel noise when goes up
My Ride: Bmw e60 530i _-_ professional navigation- mystic blue exterior- beige interior-logic7-18 inch rims-active steering-bluetooth-adaptive xenon lights-sunroof-sport steering wheel-comfort seats-tv-pdc
When my steering wheel goes up it makes a squeeky sound ONLY when It goes up but if it goes left right down there is no noise, what would the cause of the noise be ? My car is a bmw e60 530i 2005 with sport steering wheel
same here...but there is a plastic piece behind thats rubbing the wheel when going up and down. I had some work done behind the wheel and the casing behind wasnt put back properly (not seated good). maybe you can check yours too
hey there i have the same car active sterring and sport 05 530i mine makes a vibrating noise when it goes up or down when i start the car
Mine does that sometimes on super hot days [100+F]. On this Forum there was a fix that suggested opening access door on the bottom of the steering column and treating with Teflon or silicone spray. Do not use WD-40 because of the stink factor. Look for the DIY, I have not treated mine because high summer is waning and the noise is gone.
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Spray some WD-40 and it will solve the problem. It is a plastic piece that rubs agains another plastic piece!
does anybody have an idea where should we spray the WD-40
OK every car is different best would be to locate the general area that the noise is coming from and spray lightly there. I have seen on some cars you actually can see the worn out area on the plastic it looks kind of discolored and white. If you cant then you need to take apart the steering column outside plastic housing which is simple.
TexaZ3
05-06-2015 09:54 AM
