Steering Wheel Noise?
Old 03-04-2011, 06:25 AM
stevenbeboo's Avatar
My Ride: 2008 528I 2008 Triumph Daytona 675
NIce project.
Old 04-07-2011, 11:48 AM
jhr545's Avatar
Originally Posted by Bezzletine
When you take the screw out of the bottom of the column surround make sure the little black square part that the screw threads into doesn't fall out once you pull the surround off. Mine fell out and I didn't even know til I had already put everything back together. You'll need a flashlight also to see the lifting mechanism or whatever its called. Everything else is pretty straight forward. Day 2 and no noise =)
I have the same noise when the steering wheel moves up or down. I am not seeing "the screw in the bottom of the column surround" but I do see what looks like a lever of some kind roughly behind the brake pedal. I have a 2004 545i. Any suggestions would be appreciated.
Thanks
Old 04-07-2011, 04:09 PM
shorttough's Avatar
can anyone take pictures while this is being fixed, and what part has to be greased.. A picture is worth a thousand words. Thank you in advance.
Old 04-08-2011, 05:54 AM
Weebz's Avatar
Yeah, I don't see a screw on my 04 545 either and the noise is killing me.
Old 04-10-2011, 08:55 AM
neoe60's Avatar
Thanks
I get a squeaky noise when the steering wheel automatically moves up/down when you put in the key fob. The dealer has fixed it before but now I'm out of my warranty and it has come back. Will have to try these solutions when the snow here melts
TexaZ3
05-06-2015 09:54 AM
shoryuken15
04-09-2015 03:42 PM
LAMike240
F10 Discussion
03-17-2015 08:24 PM
gonzo40
01-07-2004 01:38 AM
08-12-2003 11:41 AM
Quick Reply: Steering Wheel Noise?
