Steering vibration in 520d
Old Nov 2, 2007 | 07:51 AM
ballistix's Avatar
Dose the steering wheel in 520d has vibration?
I'm never dirve diesel car. I'm not sure that virbration is nature of diesel or it is defect.
thank you.
Old Nov 2, 2007 | 08:13 AM
boukehj's Avatar
My Ride: 520d LCI, old engine, manual, black dakota, platingrau II, standard (242?) rims.
It should not have vibration. Apart from the vibration that each and every part of the car has if the engine is running. It should not be obvious when you drive. Just by comparison: the stick has some vibration that you can feel and notice each time you change gear.
Old Nov 2, 2007 | 08:14 AM
MacSid's Avatar
My Ride: G30 530i M-sport
Model Year: 2018
It would help us to help you if we knew where you are located and what year/spec your car is.
I drive a EU-spec 530d, and have no vibrations at all from the wheel. Can you be more specific in relation to when you get the vibration? It could be as simple as bad wheel balancing or something more serious depending on when/how you feel it.
Old Dec 2, 2007 | 03:32 AM
copello's Avatar
My Ride: 520d
thank you.
2 years with my E60 520d. No vibrations on the steering wheel to date !
Old Dec 3, 2007 | 11:43 AM
timewa's Avatar
thank you.
It's not normal. You may feel the engine when touching the manual transmission, but definitely not when holding the steering wheel.
You may want to have your engine checked for abnormal vibrations.
Old Dec 4, 2007 | 12:24 PM
wees75's Avatar
My Ride: BMW 550i 2007 M-Kit installed- 367 BHP Sapphire black, comfort seats, comfort access, HUD, Professional Nav, Logic 7.
thank you.
This should be a minor problem and it happens to every car after a certain mileage depending on the condition of the road that the car is used at. if you feel the vibration at stand still, try checking the engine and the gear box supports. these are like shock absorbers that hold the engine or the gearbox.... and if the vibrations start when the car is going at a certain speed then you might need to do some wheel alighnment or change your tires
Vman33
Mar 14, 2022 04:43 AM
Tymm
May 30, 2016 06:23 AM
th3h1ghlander
Oct 9, 2015 07:40 AM
EuropeanArtz
Sep 23, 2015 08:21 PM
Claudiupromotion
Sep 17, 2015 08:02 PM
