Steering or suspension noise
My Ride: Bmw 530d 2004
Originally Posted by umitbat' post='1065821' date='Dec 1 2009, 10:36 PM
Hi
05 530d makes some noisse passing over kerbs or when you steer right left stationary.
Is it suspension or steering box?
Originally Posted by Anzafin' post='1065836' date='Dec 1 2009, 04:06 PM
What kind of noise?
Originally Posted by umitbat' post='1065852' date='Dec 1 2009, 11:16 PM
A deep knocking noise as tyre passes from kerb or bad surface or as you park up to walking line.
Part numbers 11 and 16 for example:
![](http://www.realoem.com/bmw/diagrams/s/y/216.png)
Here's my simple method to look for worn suspension parts:
- lift the car up
- take a good grip of your right/left front/rear wheel --> shake left and right --> if you can feel/see any backlash, possible damage in wheel bearing
- if it's the wheel bearing, you should feel/see the backlash when shaking the wheel vertically too --> if there's not any backlash vertically, the problem probably locates in suspension parts
- if the problem is in the wheel bearing, the another way to be sure about it is to ask a friend to press the brake pedal while you're shaking the wheel --> again, if it is the wheel bearing, the backlash should disappear when the brake pedal is being pressed
Check the suspension:
- the car still up on a lift
- shake all suspension parts and watch the joints --> very highly you will see the backlash if it's there
- to see the the track rod better you have to remove some plastic covers
- also check the shock absorbers for leaks.
Note! When shaking the front wheel, there shouldn't be any backlash!
Originally Posted by umitbat' post='1065859' date='Dec 1 2009, 11:30 PM
The seller told me suspension must be lubricated.
I havent heard this before.
What about steering box?
All joints are closed structures.
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
edit: If you have a possibility, check the suspension by yourself. There shouldn't be any backlash anywhere and you will find it out by shaking and twisting those parts pretty easily.
Originally Posted by umitbat' post='1065864' date='Dec 1 2009, 11:36 PM
ok
i will take the car to a checkup tomorrow.
Of course every part will move a bit when using some force, but by a backlash I mean a clear gap that you can see or feel in a joint. I noticed some backlash on my right front wheel this summer, and by shaking and twisting suspension parts I quickly found out that it was the part 16 in a pic above.
If you can find worn out parts on left and right side, I think it is a certain sign that the car has seen more road than those few kms you mentioned in another thread.
Originally Posted by umitbat' post='1065821' date='Dec 1 2009, 12:36 PM
Hi
srogers535x
08-05-2015 08:48 AM
jeffandjaimie
07-08-2015 05:48 PM
