Steering module failed - HELP!
My Ride: 2007 E60 530d
Engine: M57
Hi all.
2007 530D LCI
Couple of weeks ago I did the following work
Since then I have active steering error - ISTA cannot communicate (much) with the AL module.
ISTA can sort of talk to the module to read/clear codes but it cannot perform the steering motor angle calibration. Keeps saying communication not possible. I don't mean the steering angle sensor - that is OK.
Battery is tested and looks good.
So I have no DSC, active steering or ABS.
Anybody heard of this kind of thing happening.
Seems incredibly coincidental but I didn't disconnect any steering related plugs anywhere. Maybe raising the motor did something.
Completely at a loss - hoping not to remove module if I can help it.
2007 530D LCI
- Disconnect battery
- Change engine mounts
- Disconnect steering column from rack and push up and out of the way (after I disconnected the battery I had to move the steering column by pushing on the front wheel to get spanner access to a bolt).
- Remove turbo for a look over (bit low power but turbo seems OK)
- Reassemble
- Connect battery
- Start
Ray88
Oct 28, 2008 07:51 AM
