Starting from cold, rough running
Old Nov 15, 2012 | 08:07 AM
stewart@pt.lu's Avatar
Exclamation Starting from cold, rough running
Hello all, I am new here and hoping you guys can get a newbie out of trouble
The car is a 2007 E61 530i with the N53B30A Engine.
When starting on a cold morning for the first few minutes the engine run rough, slow to pick up, hunts at idle and seems to misfire.
Once I have the throttle down it is much better, still notice the misfire though
After a few mins driving the fault disappears and the car runs great. It feels like the problem improves rather than just instantly disappears but this could be just my feeling.
At the time when it goes away I am always driving up a very long hill so throttle down and the engine is really working.
When I leave work later in the day the “misfire” is there but nowhere near as bad, its warmer at that time of course.
I was told MAF, so I got a nice shiny new one, genuine BMW part not a copy, the old one did look dodgy, should the white plastic part be floating loose just held by the 2 wires??
New MAF fitted, identical fault, no change at all.
I scanned for fault codes ODBii things, not one, nothing. No warning lights or service indicators either. I had it scanned with engine off, engine running and misfiring and engine running nice and warm and perfect. Nothing.
My next guess is an O2 sensor however I’m told these don’t come into play until the motor is warmed up, is that correct. Open loop/closed loop ?
If not then what tells the engine that it is not cold anymore? How is mixture metered when its cold?
Car is out of warranty and the local stealers apart from being very unfriendly and unhelpful charge a total fortune just to say good morning.
Sorry the request is so long, I tried to give as much info as I could.
Old Feb 25, 2013 | 10:45 AM
JohnB75's Avatar
My Ride: '05 545i
Did you make any progress on this? My '05 545 is doing the same thing.
Old Feb 25, 2013 | 11:38 AM
AchtungE60's Avatar
My Ride: E60 530i
This sounds like an issue i had years ago with the electronic intake regulator (DISA) so track it down to there. It is all ice cream just different flavors.
Old Feb 26, 2013 | 06:15 AM
paran's Avatar
My Ride: 2005 545i Sport
Sounds like an injector issue. Fuel saturates the combustion chamber and spark plug when the injector is leaking.
I'd bring it to the dealer or trusted indy shop and leave it over night for an early AM test.
Islandstream
Apr 29, 2019 11:24 AM
md750i
Apr 8, 2015 09:13 AM
md750i
Apr 8, 2015 06:08 AM
Stranger12
Apr 5, 2015 10:42 AM
