Starter Problem?
Old 11-25-2013, 08:48 AM
  #81
pcy
pcy's Avatar
Disconnect the MAF (Mass Air Flow sensor) and try to start and let me know the result.
Old 11-25-2013, 08:57 AM
  #82
pcy
pcy's Avatar
Originally Posted by E60I
Do you think the fuel pump can be the cause of this crank but no engine running probem? How can I test the fuel pump to see if it works or not?
Thanks!
Usually, there is a valve at the end of fuel rail for fuel gauge connection. I don't remember if N52 fuel rail has. If there is a valve at the end, connect fuel guauge and see if there is fuel pressure.
Before you test the fuel pressure, when you insert the key and turn the ignition to position 2 (don't try to start the car), do you hear fuel pump pressurizing the system for few seconds? If necessary, pull out the rear seat bottom and listen for the fuel pump humming.
Old 11-25-2013, 08:59 AM
  #83
E60I's Avatar
My Ride: 2006 BMW 530I
Model Year: 530i
Oh my god, YOU ARE A GENIUS!!!
After the MAF is disconnected, the car starts and run on my first try. It runs rough! How long should I let the engine run to see if it can smooth out?
While the car was running rough, I connected the MAF back. As a result, the engine shuts off.
How can we fix it?
Thanks!
Old 11-25-2013, 09:32 AM
  #84
zgilbert's Avatar
My Ride: 2008 528i Sport
Disconnect your negative battery terminal. Let the car sit for 15 minutes. Then reconnect the cable.
Turn on the ignition but DON"T START the car. Let it sit for 1 minute with the ignition on. Then turn off the ignition. Now start the car.
Doing so resets the PCM.
Didn't you say the car runs for APPX 3sec?????
Old 11-25-2013, 09:33 AM
  #85
zgilbert's Avatar
Gotya on the MAF!!! Try resetting the PCM as I described above.
Old 11-25-2013, 10:14 AM
  #86
E60I's Avatar
Model Year: 530i
Hi zgilbert and Pcy,
I did the reset like zgilbert suggested. The car cranks for a second and that's all.
Bentley service manual suggests to check and clear fault codes from ECM memory after reinstalling mass air flow sensor. How do I do that?
I do have INPA installed in my laptop. I can do it if someone would kindly show me the steps.
Thank you so much!!!
Old 11-25-2013, 11:39 AM
  #87
pcy
pcy's Avatar
I think the MAF was damaged while removal/reinstallation process
OR
the MAF was defective prior to the starter installation.
Try cleaning the MAF sensor with MAF sensor cleaner (auto parts stores sell them). The part that looks like a wire/resistor in the MAF is a delicate part. While trying to clean it, don't let the spray nozzle touch that wire part. Spray the cleaner liberally, let it dry, and install. If this doesn't work, I am afraid you may have to buy new MAF,
Old 11-25-2013, 12:13 PM
  #88
zgilbert's Avatar
I agree with pcy on this. If the MAF unplugged allows the car to start, you should get a Check Engine Light. If you plug in the OBDII code reader the code should be PO101 or PO102 for MAF.
Hopefully when you clean it, all is well. Good Luck!!
Old 11-25-2013, 12:24 PM
  #89
zgilbert's Avatar
BTW I use an Actron OBDII code reader tool. It makes ease of reading erasing codes on all brands. I have used it on Ford/Chevy/BMW/Porsche/and Toyota.
Buy Actron Auto Scanner OBD II Code Reader CP9575 at Advance Auto Parts
I haven't used the INPA program before, so I can't help there
Old 11-25-2013, 12:46 PM
  #90
zgilbert's Avatar
Found this.... But gotta go.. gotta pack and get the family out of town for Thanksgiving
Good Luck!
Quick Reply: Starter Problem?
