SSS Progman - Batttery charger?
I need to program my retro fitted heated seats.
I can use INPA no problems.
When trying to use SSS Im stuck on the 'Connecting' screen is this beacuse I have no power connected?
I have the followng battery charger will it do the job?
http://www.argos.co.uk/static/Produc...7C14418754.htm
Also what to I select to programme the seats?
THANKS
THANKS
No sorry that will not work for anything. You need about 20 amps to keep the constant 13volt.
That's probably not why you're stuck at the connecting screen though. Does it even get to the CKM or Load Software/Retrofit path? If not then look in front of the program.
Not got to the CKM/load screen. Im using VM its most prob not set up right....
I read somewhere you keep ODB COM1 communication on the main laptop not from VMware. I have disabled windows firewall and now can PING 192.168.68.1 from VMWARE.
So hopefuly in the morning I will be able to connect SSS/progman no probs.
Disabled Windows firewall and third party firewall - ALL WORKING NOW
Awest91
Sep 17, 2022 11:05 PM
