Squeaky steering wheel resolution
Old 01-29-2009, 03:46 AM
LW78's Avatar
My Ride: 535dA M-Sport Carbon Black Nasca Black leather AFS Comfort Access Moonroof Active seat vent Xenon Navi Prof. Night Vision HUD High Gloss Shadow Line
Originally Posted by mini_me' post='780063' date='Jan 29 2009, 01:43 PM
I try not to but currently I drive both types on a daily basis...
Let me know the DOT# and how much thread there is left
Btw, then you will also notice the advantage in handling over a FWD car!
Old 01-29-2009, 08:07 AM
mini_me's Avatar
Dunlop SP Sport Winter RFT tires.
About 6mm profile depth and DOT 1104
Old 01-29-2009, 09:05 AM
LW78's Avatar
Ok, so you're running Winter tyres. Those also provide a different road feel.
DOT 1104 means that the tires are produced almost 5 years ago (week 11 in 2004), so they are early generation RFT's. I think you're problem will be solved after changing the tires. If not, the car will drive at least a lot better! Changing to regular tyres will give you a whole different car!
Old 01-29-2009, 09:36 AM
mini_me's Avatar
I will try my 16" summer tires (brand new) and see if this changes the feel. THX!
Old 01-29-2009, 09:57 AM
Howitzer's Avatar
Originally Posted by porsche911targa' post='778403' date='Jan 27 2009, 12:13 PM
Hi,
Just wanted to share my experience in the hopes that it would help the membership with future issues:
A while ago, my 2006 E60 developed a squeak in the steering wheel when turning either left or right. It sounded to me like when rubber expands and rubs up against something solid; squeaky rubber.
I took it to my excellent dealer who confirmed the squeak even with the engine off. They wrote that SIB 32 17 08 applied to the situation and tried a bunch of things that did not work. Ultimately, they submitted PUMA case for possible steering rack replacement.
PUMA case replied with complete flush of power steering system and bleeding procedure.
This is what they did (written word for word from invoice)
"Per PUMA case, removed return line to P/S reservoir and flushed P/S system new Penticin till pure clean Penticin was flushed. A) Per outlined bleeding procedure replaced power steering reservoir containing P/S filter. Replenished complete power system. Then performed extended bleeding procedure outlined in the PUMA case by running engine at 2500RPM and going lock to lock with brake pedal depressed until P/S steering fluid obtained 105 deg C. then let brake pedal go and turned steering lock to lock 20 times. This procedure was completed 2 more times. This procedure was successful with no more squeaking from steering column. Even when vehicle sat for 2 hours and retested. Tested OK."
Only had the car back for one day and so far there are no squeaks. I will monitor this and will report an update to the membership in about a month or so, if desired.
I was wondering if anyone else has experienced this in the past and, if it was resolved the same way, did it it fix the problem permanently or is this a patch that will last long enough until I run out of warranty? The only thing that bothers me is that the dealer was able to duplicate this even with the engine off, so I don't fully undersatnd how the procedure above worked.
To the technical geniuses here (I.E. the moderators) why do you think that this procedure would eliminate a problem that sounded like a physical rubber something was rubbing against something else?
To BMW, if this resolves the problem, you guys are geniuses. To my dealer, FMW of Natick, you guys are simply the best. Thanks for working hard and always making sure that this picky customer leaves with a smile on his face. What's up with the crappy Enterprise rentals, though?
If the above procedure will help even one member I will be very happy.
I had this same issue on my 2004 530i. I took it to the dealer, they performed the same type of job and it was covered under my CPO. Its a known defect.
Old 01-29-2009, 10:08 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Is it this noise?
http://forums.e60.net/index.php?s=&sho...st&p=399642
Old 01-29-2009, 10:27 AM
marklp's Avatar
Thanks for finding my old thread
For the record, the new steering rack definitely fixed the problem - no squeaks or whines since.
Maybe flushing the fluid sorts out the problem before the rack gets knackered? There was no messing about with mine - it went in to the dealer with what I'd call a mild irritating noise and I received the phone call to tell me they'd condemned it
Old 01-29-2009, 11:44 AM
porsche911targa's Avatar
Originally Posted by twh' post='780292' date='Jan 29 2009, 02:08 PM
No it was more of a squeak/whine. That's a great idea, though. I'll have to remember to video my next noise/squeak/rattle issue and post it. Thanks for the tip.
I still don't understand how P/S fluid can cause a whine.......
Old 01-30-2009, 01:27 AM
Knut's Avatar
Hi
I had a similar procedure done on my 2005, E60. Experienced the same noise. I could also feel it in the steering wheel.
What they actually did was going lock to lock with the steering wheel while monitoring the temperature in the steering fluid reservoir, stopping at 90 degrees Celsius.
The explanation for this was that the spindle is hollow. The increase in temperature and pressure causes the hydraulic fluid to rise and thereby rinsing and lubricating the spindle.
The noise disappeared for three months, and, as you may have guessed, has now returned.
I didn't quite like this procedure. Hydraulic oil is designed for pressure and contains detergents. It's never used for lubrication.
I found this DIY on Bimmerforum. Hope you find it helpful.
http://forums.bimmerforums.com/forum...d.php?t=245961
Regards Knut L., Norway
Old 01-30-2009, 08:12 AM
How long ago was this done? I'm trying to figure out if this is a short term solution or if it really takes care of the problem.
Thanks
Quick Reply: Squeaky steering wheel resolution
