Squeaky brakes.
Old 06-26-2009, 11:47 AM
Ricracing's Avatar
Originally Posted by Dandle' post='924847' date='Jun 26 2009, 09:05 PM
I did, you said "a couple of hard brakings and the problems is gone". It isn't in my case it's still there.
Cobra 427 explains it bit by bit...
Old 06-26-2009, 12:06 PM
v_therussian's Avatar
hmm always thought that squeaky breaks are ok as long as they are not grooving the rotors...
Old 06-26-2009, 09:02 PM
rodneyremington's Avatar
My Ride: 2005 545i with everything
I had the same issue, and they were changed (pads AND rotors) under warranty no disputes at all at 43,000 miles!!!
Old 06-27-2009, 10:00 AM
ey2001's Avatar
My Ride: 525i
mine squeaks also... i tried braking hard from 70 to a full stop... still squeaks.. it only squeaks on the right side... i got it done right b4 my warranty ended... drove like 15k miles... i even tried pulling the pads out and spraying the stuff so it wont squeak... still the same... should i just replace the pads? the pads are still meaty... and pads are like 130
Old 06-28-2009, 09:59 PM
That's the same question I'm contemplating! My pads look ok, so do the rotors, but I'm dissatisfied with the performance of the brake pads AND the squeaking is REALLY friggin' annoying - my car had an almost 60k sticker when new, I don't want my brakes to sound and perform like they belong on a regular yellow cab!
Old 06-29-2009, 03:31 AM
stanatl's Avatar
My original brakes never squeaked and when it came time to get new ones (front and back) I talked to my SA becuase I was concerned about the posts about squeaking brakes. I had them on an Audi A6 4.2 that I once had and they drove me crazy.
My SA told me not to worry - that as long as they replace the sensors there should be no squeaking. I don't know if that was the case or not, but I have no squeaking with the new front and rear brakes.
Old 06-29-2009, 07:41 AM
melimel's Avatar
god this sounds like a horrible recurring nightmare.. i had this same problem.. i ad no problems whatsoever till about 16 or 17 k.. then it was this high pitched squeak only when touched lightly. hub said sounds like the sensor.. i took it to the dealer they said the pads needed to be changed.. i said okay fine.. whatever. so they did it.. and then i came home with a squeak so loud it would wake the dead! i was pissed, took it back they told me that "brakes occasionally squeak and its normal" fu%* that crap man.. the loud embarrassing squeak went away. but now i have this high chirpy squeak even when im not touching the brakes.. !!!
i can just be driving and i hear it as the wheel is turning and it gets faster as i speed up.. i dont know what it is and now i fear its not even a brake issue.. sometimes the dealer has helped me out and sometimes i think there stupd mofo's.. i hate having these problems.. sorry to jack the thread dude hope your problems get resolved and mine as well.. i have yet to bring it back
Old 06-29-2009, 10:33 AM
ey2001's Avatar
My Ride: 525i
what did you end up doing? the squeaking on mine got worse.. when i make a left it makes the sound.. very annoying... also the sensor is on the driver side too right? i didnt see the sensor on the passenger side
msaudino
11-01-2015 03:52 PM
e36er
03-14-2008 02:14 AM
fraseman999
03-17-2007 02:28 AM
smokin
29
10-27-2004 03:59 PM
Kiasu King Kong
07-20-2004 01:13 AM
Quick Reply: Squeaky brakes.
