Squeaking noise in the steering colum , only during cold starts.. any
My Ride: 2004 530isport packagepremium packageactive steeringxenon hids20mm H&R spacers in the rear6 spd51kpurchase price , 32k back in 2006
Model Year: 2004 530i
Thanks for your time~
Some history about my car , I bought it with 42k , it now has a 140k.
The problem is a squeaking sound when you turn the steering wheel from left to right. It only occurs from a cold start and usually lasts for about ten minutes of driving...
Is it possible the steering rack needs to have some grease applied ?
If you had this problem please chime in!
thanks again~
thanks again~
what is the condition of the engine drive belt? If the belt is [new] good, then I'd check the PS pump. Drop the belt, and spin the PS pulley. If you hear any noises, then replace the PS pump.
thanks for chiming in..
engine belt , as in the timing belt?
my power steering is leaking but not a serious issue as of yet...
I will check the ps belt today . Is it pretty difficult to access the belt and pulley?
for sure , how about 5 grand each?
this is a fairly common issue here in the UK on both E60 and E61 cause by the steering fluid being too viscous (thick). The treatment here by BMW UK is to raise the temp of the oil to 70c then drain it off and replace it with oil from the BMW Mini range - squeek then gone!
srogers535x
08-05-2015 08:48 AM
