Some Blue Liquid on my Garage floor.
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Originally Posted by Krozi' post='783164' date='Feb 2 2009, 10:56 AM
Thanks should I check when the engine is cold and off or cold and on?
If you don't have an owner's manual one is available for download at the INFORMATION section of this forum. This is an extract from it:
Originally Posted by luigi524td' post='783165' date='Feb 2 2009, 10:57 AM
As with any inspection of the car's cooling system - COLD AND OFF!!!
Originally Posted by Krozi' post='783183' date='Feb 2 2009, 11:24 AM
Ok thanks. Where exactly is the cap for the coolant? Most of my caps on the car have oil on them and I am not quite sure shich one is which.
OR ... you could RTFM
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Originally Posted by luigi524td' post='783435' date='Feb 2 2009, 05:30 PM
I'm very happy to be of service. Please process $2,400.00 [my minimum daily consulting fee] to my paypal account.
OR ... you could RTFM![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
My coolant reservoir cracked at 70k miles in my e60, and on my 540 e39 the radiator went bad at 99K miles. On both BMW's these were plastic parts, and probably on the F10 it'll be plastic too!! horrible material. But on both instances i got warnings (low coolant level in the idrive e60, and smoke coming out from my e39! )
As previously said above, when you check the levels, make sure the car is cold.
GL.
GL.
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
My Ride: 2005 silver gray metallic 530i with sport package, premium package, cold weather package, navigation, and L-7 audio.
I realize this is an old thread, but I located similar color and consistency fluid on my garage floor too! Did you ever confirm the source and identify the fluid? I agree with the previous post and believe it's antifreeze too. How much was the cost for repair/replacement for the plastic resevoir tank (or estimation of the cost)? Thanks in advance. I'm a little freaked to see that my car is leaking. damn...
Remember this thread?
When I was installing my RPI Scoop, I took the time to also check all fluids.
It turns out my Coolant was at the absolute minimum. I drove to the dealer and it turns out they had to replace the hose that was going to the radiator because it was leaking.
Glad I discovered it ahead of time
PelicanParts.com
Meet & Greet Discussion
10-16-2015 03:07 PM
DetailersDomain
Detailing Forum
09-03-2015 07:08 PM
