Settings Seldom Change with Key Changes:
Originally Posted by VTec' post='314702' date='Jul 25 2006, 04:50 AM
I think some people misunderstand that the key simply moves the settings back to the same settings the car was locked with (using that key), not one of the actual memory settings.
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
Originally Posted by Znod' post='313446' date='Jul 20 2006, 09:35 PM
Has anyone else ever had the problem I described? I always assumed that it must be very common since it exists almost all the time on both of our BMW's.
cheers
vern
Originally Posted by VTec' post='314702' date='Jul 24 2006, 10:50 PM
I also have this problem and am convinced that some kind of static discharge is occasionally happening that erases the key settings.
Also, I think some people misunderstand that the key simply moves the settings back to the same settings the car was locked with (using that key), not one of the actual memory settings. Of course, for most of us, one of the memory settings IS how we left the car when it was locked with the key, so they usually are the same setting anyway. However, at least if your settings are saved to a memory location (1 or 2) and the key fails, you can reset everything, lock the car and you're back in business.
Drive and lock with key 1--which is programmed with the M1 settings.
Unlock with key 2.
The physical settings should change to the key 2/M2 settings assuming that key 2 is programmed with the M2 settings that differ from the M1 settings.
Originally Posted by vern' post='314817' date='Jul 25 2006, 07:39 AM
Had and have this problem on every BMW I've owned.I gave up on it because as much as I would like it to work its no big deal if it don't. Good luck
cheers
vern
cheers
vern
ON ORDER
Originally Posted by Znod' post='314827' date='Jul 25 2006, 09:32 AM
Thanks Vern.
cheers
vern
Stormcrow
Dec 1, 2019 02:09 AM
rackhacker9275
26
Apr 16, 2015 08:13 AM
