SES light
Old Nov 9, 2010 | 11:53 AM
qtrtil6's Avatar
My Ride: 2004 Bmw 545i
My Service engine soon light is on and my screen is giving me a increased emissions warning. So I took my 2004 545i to a local part store to get the codes read and it seams that all four of my oxygen sensors are showing bad. I priced the sensors and it seems that the manufacture part cost about $242.00 a piece. Is this common for the upstream and down stream sensors to be bad at the same time? And if so what would cause this? Also I'm thinking about doing the work myself is there anything I need to know on how to D.I.Y.?
Please help labor cost $70.00 per sensor
Thanks,
Qtrtil6/545 owner
Old Nov 9, 2010 | 12:18 PM
Bimmerchop69's Avatar
My Ride: 2004 BMW 545i 6mt, Titanium Silver, Sport Package, Winter Package
The Increased Emissions has nothing to do with the O2 sensors. You will get another error if it was an oxygen sensor. From my experience with my 545i is it could be a vacuum leak. loose gas cap, thermostat??<--- very questionable... There is a thread I started and another someone else started with this issue. Im pretty sure its not your O2 sensors.
Old Nov 10, 2010 | 06:12 AM
qtrtil6's Avatar
Thanks 'Bimmerchop69' for your reply Im going to look into that before I spend 1,200 on parts and labor for the O2 sensors.
Old Nov 19, 2010 | 10:44 AM
qtrtil6's Avatar
Update: I found I had a valve cover gasket leak and was loosing some oil. Thats when I found I had to change out the crank case hoses. I think that was the problem the whole time. Now my car seems to be running fine.
Thanks,
545i/qtrtil6
Old Nov 19, 2010 | 11:03 AM
mels545's Avatar
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up! 04 545i all the goodies INCLUDING HEADACHES!
I was also getting the SES increased emisions fault. I replaced the VC and timing gaskets but the light came back on. There was another gasket on the lower drivers side of the engine that was pouring oil. After this was replaced the light has not come on. If you still have an oil leak after the gasket repairs check this gasket. It's very difficult to see behind the alternator support bracket without an inspection mirror and a PITA to replace.
DavaiLave
Aug 2, 2022 02:16 AM
BMW565
Nov 6, 2017 06:03 PM
thesalboy
Apr 8, 2015 09:13 AM
rizwan1377
Apr 5, 2015 05:22 PM
Stranger12
Apr 5, 2015 10:42 AM
