Service engine soon
My Ride: 2005 525i (plain and simple)
Increased emmissions? Hoped it was just the gas cap...it wasn't. Is this a "get to the dealer" ASAP? Car is running fine.
Thanks
Thanks
check this thread
http://forums.e60.net/index.php?showtopic=...mp;#entry528727
also helps if you put your e60 details somewhere for forums members to see..helps to answer q's...
Originally Posted by geneatals' post='571663' date='Apr 30 2008, 02:46 PM
check this thread
Originally Posted by BarryNH' post='571680' date='Apr 30 2008, 11:58 AM
Thanks! I'm still learning my way around this forum, will add details. Great forum.
not a problem...and to the forum. A lot of answers can be found by using the upper right search bar also. Enjoy the forums...
My Ride: 04 545i silver grey, 6spd, comfort seats, L7, sport, cold weather, rear heated seats
Well it had to happen to somebody else, I just got that error message too. I have an appointment tomorrow, so we'll see how it goes.
good luck to the both of you..keep us posted...
They had my car fixed in a few hours and said it was the thermostat. No charge so no complaints, except I'm beginning to see my SA more than my car.
Common fault with multiple causes. I recently had the same thing. Repair (in my case, crankcase vent valve replacement) was covered under CPO warranty. While I was there they also found a faulty oil sensor, and replaced that too.
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
TexaZ3
05-06-2015 09:54 AM
thesalboy
04-08-2015 09:13 AM
