Service engine light & module updates?
My Ride: 2006 530i
If the throttle body was removed, try this. It needs to be readapted before you try to start the car afterr removing and replacing. Turn the ignition to the run position but do not start, wait for 15-20 seconds and turn key to off, then start the car. The mixture faults could be due to a vacuum leak. Try checking the integrity of the various vacuum hoses as they dry and crack. also make sure the the air intake boot that leads to the throttle body is stight at the clamps and that there are no cracks in the boot. you can also try spraying wd-40 around various areas of the intake system to check for a leaking manifold gasket. To do this, with the engine running, spray wd-40 around suspected areas of the leak, if the engine tone changes, (ie smooths out then runs rough) you have isolated a leak to that area. Hope this helps.
thesalboy
04-08-2015 09:13 AM
