Service Bulletin to relocate MPM
My Ride: 545i
I don't think this procedure would be covered by warranty unless you had a leak. But you'd think they would rather do this easy fix instead of having to repair/replace a bunch of expensive electronics under warranty. Maybe phone, give them the SIB# and see what they say. You will probably have to pay to get it done. Or do it yourself.
My Ride: 545i
Finally got around to doing this. I placed the PDC where BMW suggests and the MPM right next to it using double sided tape. I tried to route the wires as they suggest as well. You have to separate some of the taped strands to make the wires go where you want. I re-taped them to look OEM. You also have to trim some of the plastic supports on the back of the interior trim exactly where the MPM is and along the rear body panel to accommodate the extra wires.
Tools>TSB & Recalls ( https://5series.net/forums/alldata.p...2012/makeid=6/ )
My Ride: 545i
looks like other members chimed in well and you got things sorted, but for future reference, try using the new forum feature under the "Tools" menu in the top nav bar:
Tools>TSB & Recalls ( AllData - Technical Service Bulletins )
umnitza
Nov 25, 2015 11:10 AM
EuropeanArtz
Sep 23, 2015 08:21 PM
Bogdan7
Sep 23, 2015 11:40 AM
