Service Bulletin on problems updating with CIP 19.x
This seems to confirm some members experience with CIP updates.
Also note that it appears BMW is changing the convention on the software upgrade title from CIP to PROGMAN xx.xx.xx
SI B 09 11 05
Programming/Coding Explanations December 2005
Technical Service
SUBJECT
CCC Fails to Program with CIP 19.x
MODEL
E90, E91 (3 Series) with SA 609 CCC-Navigation
E60, E61 (5 Series) with SA 609 CCC-Navigation
E63, E64 (6 Series)
SITUATION
While updating the software on the CCC (Car Communication Computer), one or more of the CCC components fails to program. Various CoApi fault codes are displayed in the Final Report. It is no longer possible to communicate with or reprogram the module using CIP. No sub menus are displayed in CIP when the control module text is displayed in red.
CAUSE
CIP application logistics error.
PROCEDURE
Perform a battery reset on the vehicle for 15 minutes.
Restart CIP and when asked "Have control modules been replaced?" Answer "Yes" and mark off all 5 components of the CCC.
Follow the CIP prompts until programming is finished.
If programming still does not complete successfully, submit FASTA data along with a PuMA case to the Electrical Group Hotline.
With the release of Progman 20.00.00 this error has been corrected.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
SI B 09 11 05
Technical Service
SUBJECT
MODEL
E63, E64 (6 Series)
SITUATION
CAUSE
PROCEDURE
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
SI B 09 11 05
Technical Service
SUBJECT
MODEL
E63, E64 (6 Series)
SITUATION
CAUSE
PROCEDURE
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
SI B 09 11 05
Technical Service
SUBJECT
MODEL
E63, E64 (6 Series)
SITUATION
CAUSE
PROCEDURE
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
My Ride: 530d Sport, Mystic Blue, Dakota leather,Professional Navigation,BMW Assist, Blue Tooth Prep +telematics, 6 Disc Changer, ML/Alloy 8jx18", Graduated Tint windscreen, Auto-Dim Int + folding Mirrors, Comfort Seats - Electric, Through Load system inc Ski Bag, Bi Xenon Headlights plus washer system, Automatic Air Conditioning-Advanced, HiFi Speaker System, Fitted Floor Mats, clear bra
This may explain why my car had to be kept in overnight after re-programming for an aux input. Garage phoned and told me they were having problems with the reprogram and would have to start over.
Thanks for that one.
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
cheers
vern
Faizd
04-27-2015 12:16 PM
