Seat Removal - Passenger Restraint Error
Hi All - I removed my passenger side front seat to clean underneath it (I won't tell you why - it's disgusting). And I now have a Passenger-Restraint Error. I did it with the key off but did not disconnect the battery (this TIS did not say to do this). What's weird is that when I first moved the car after I did it, there was no error. But the next morning when I started the car, it came up immediately. I checked the connections under the seat and everything is in tact.
Any idea on how to reset it without going to the dealer? Will disconnecting the battery help?
My Ride: 06 530XI Sapphire Black, Black Int. 6sp, Cold, Prem
I think that may be a recall. As I mentioned on another post, I took my 06 in for maintenance and brakes. My SA mentioned that they had to take the cover off the passenger seat to check for a product number to see if my car was involved. I didn't need the fix since it was out of range. Just a thought
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Disconnecting the battery no need, cos that error code stored in memory and need to erase by s/w.
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front.
Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
yup bring it to a shop, the pre-tensioner will not work now and it's dangerous.
not all shop has the latest scan tool that can clear it. i went to one and their scan software is not the most up to date. luckily my friend has a tool and did it for me for free.
some shops will do it for free as a courtesy, at most they will charge you half hour of labor. the nearby dinan said they will charge half hour of labor ($70), another place tried to reset it (for free) but the error didn't go away. long story short i wiggle the connection and later my friend helped me clear the code.
Yup I had that light on too. It's passenger restraint malfunction right? If so contact your dealer. It's under a recall of seat occupancy sensor. I just got mine done
