Seat bottom squeaking and creaking - any way to oil it?
Old Jun 1, 2010 | 03:49 AM
ucla95's Avatar
My car has about 26,000 miles on it, so some age - but now when I sit down or accelerate or stop the drivers seat bottom cushion makes loud squeaks - like an old recliner. Is there any way to get at the frame to oil it?
Old Jun 1, 2010 | 04:38 AM
luigi524td's Avatar
Need more info - is it a 'metallic' squeak or one that is more plastic sounding? It may be that the leather (or vinyl if you don't have the Premium pkg) is dry and needs to be treated. And are you sure it's coming from the seat - sounds can travel strange routes and often aren't where they seem to originate. You may be hearing the dreaded door-frame rub?
Old Jun 1, 2010 | 05:55 AM
ucla95's Avatar
It's a metallic squeak - not the leather - very clearly the metal frame underneath my rear end. Just like an old chair in your living room.
Old Jun 1, 2010 | 06:14 AM
luigi524td's Avatar
Checkthe attachment points to be sure the frame is securely tightened to the floor; there are also several frame sections supporting the seat pads and foam. One or more of them may have broken and be impossible to see without removing the seat covering and foam. Probably best done by removing the seat from the car.
Old Jun 1, 2010 | 03:18 PM
wantmye90's Avatar
My Ride: 2008 535i, platinum gray with cream beige dakota leather, premium, sport, comfort access, navigation, heated seats, sport auto with paddles, premium sound, sat radio, ipod
I have this too! I can do a seat position adjustment back and forth, up and down and then return to the same position and for a while the seat will stop creaking. Alas, with time, it returns. I think if I take to my dealer they will throw me out = my car has had it's share of problems, the least of which is this.
jfmartin25
Nov 2, 2022 01:42 AM
dsummersm3
Nov 14, 2019 07:50 AM
Karmtec
May 5, 2015 03:56 AM
Mark-Yorkshire
The Competition
Mar 1, 2004 02:12 PM
