Seat Adjustment - sports seats
Originally Posted by idoru' date='Jul 28 2005, 01:12 PM
My wife, who views most trips in the car as an opportunity to get in a? crafty snooze,
[snapback]154008[/snapback]
don't they all?
Originally Posted by kryptokat' date='Jul 27 2005, 10:53 AM
I haven't been comfortable in the sport seats on my 545i since day 1. My right hip starts hurting everytime I sit in the car and drive. I have tried at least over 50 different seat settings till now and nothing works. I just assumed it was me. (also avg build but gym every 3-4 months and run every 2-3 years)
[snapback]153589[/snapback]
My Ride: 11 550i Sophisto Gray/Oyster Black/Anthracite, Sprt Trns, DHP, IAS, SP, PP1, PP2, CWP, HUD, DAP, AVSP, SF RS, CA, ACC - Euro Del
I had the same problem. My wallet was pressing on my hip so that I could not sit square in the seat. I remedied it by taking my wallet out before I get in the car. I put the wallet in between the parking brake and the console. Comfort is much better. I have the lumbar support so that helps. With adjustment I like the sport seats a lot.
My Ride: 2004 545i, Jet Black/Black, Manual, Sport, Logic 7
Originally Posted by pharding' date='Jul 28 2005, 02:08 PM
I had the same problem.? My wallet was pressing on my hip so that I could not sit square in the seat.? I remedied it by taking my wallet out before I get in the car.? I put the wallet in between the parking brake and the console.? Comfort is much better.? I have the lumbar support so that helps.? With adjustment I like the sport seats a lot.
[snapback]154170[/snapback]
My Ride: 545i; Manual Shifter
I had this problem in my older car which was a manual shifter. My left thigh would ache after long drives but it was because the seat was not adjustable in that it wouldn't allow for tilting.
Now, I drive an e60 manual but I tilt the front of the seat downward so that it is closer to being horizontal. This distributes my body weight over more surface area of my thighs and I'm able to step on the clutch pedal without problems for hours on end.
I would like to be able to do this too, but my wallet always falls through.
Originally Posted by pharding' date='Jul 28 2005, 05:08 PM
...I remedied it by taking my wallet out before I get in the car.? I put the wallet in between the parking brake and the console.
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
I've started having upper back problems only since getting my e60. I bought a "lower" seat support and that has seemed to work - at least so far. Wasn't sure if it was the lack of the lumbar support or not. I'm 6' and 2...much!
I have to say that I found the sports seats in my E60 to be superb. If you have a reasonably long leg I found that the most comfortable position was to tilt the base of the seat so that the front section is raised and the rear section lowered. I then pulled out the under thigh support. In this position your thighs are properly supported by being raised higher than your hips and this gives much better comfort. If you have the base set too flat or the seat tilted in the reverse way you will put unecessary strain on your thighs which will transmit to your back as your body automatically compensates for the pressure on your legs to support themselves.
The backrest angle is a matter of preference but I found that tilting it back just around 5 to 10 degrees from the vertical gave good support.
the sport seats are the worst.... it's not you.... my back was also hurting after 2 weeks in the 545i sport..... too MUCH lumbar, in at it's lowest setting...
Originally Posted by realtyman' date='Jul 28 2005, 10:07 PM
I've started having upper back problems only since getting my e60.? I bought a "lower" seat support and that has seemed to work - at least so far.? Wasn't sure if it was the lack of the lumbar support or not.? I'm 6' and 2...much!
[snapback]154205[/snapback]
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
I've got my sport seats set up nicely - no pain and I like the support and fit. There's an article in the new BMW Magazine. The article quotes doctors and the head instructor at BMW Driver Training. Among other things, they discuss seating position:
"The correct sitting position, which includes having the seat height as high as possible, also includes sitting at a distance from the steering wheel so that your outstretched arms meet the sides of the wheel with your wrists, and the distance to the pedals should be such that when the clutch pedal is fully depressed, the knee is still bent. Also, remember to take your wallet out of your back pocket; there are still plenty of drivers who sit uncomfortably on their small change and then wonder why they have back pains."
I'm of only average height, yet I have the front bolster extended a bit, so it meets me at the knee joint. I find that extending it actually lowers the pad a little so that it isn't pressing up into the back of my left leg when the clutch is depressed.
It's funny, I was at the orthopaedic surgeon a couple of weeks ago (unrelated knee thing) and I asked him if there was any rule or trick to getting the seat in your car set up correctly, and he said not really. Then this article came out...
My Ride: Arrived 3 June 2005: 2005 545i - Orient Blue, Black interior, Sport, Steptronic, Cold Weather, NAV, Sirius, Logic7, Comfort Seats, Sunshades. What a glorious ride!
