Satnav question
My Ride: E60 530d Sport - Carbon Black, Black Dakota Leather, Media Pack (satnav, bluetooth, CD changer), heated font seats, through load
I haven't yet worked out how to stop the satnav from giving directions.
1) Is there a quick way of muting the voice directions. That is, other than using iDrive to disable it.
2) How do you cancel a destination, without entering a new one.
I'm used to being able to either switch off or disable the satnav (in other cars). But the E60 seems to keep giving directions. Where you get close to a destination, but not right to it. Then when you drive away, it is still giving directions to that destination.
While messing about I discovered that holding the iDrive knob to the right will "shortcut" you to the nav screen. WIthout having to use the menu button. You can also do the same to jump to the phone screen, or radio screen.
Any other useful tips on using satnav or iDrive, that aren't immediately obvious.
(yes I will read the manual in detail sometime soon too )
You can click on the selected destination again and click "Continue Guidance" or it may be "Start Guidance." That will deselect it and the lady will shut down.
My Ride: Oxford Green E60 530D with tuning box and all the toys!
The default function for the diamond button on the steering wheel mutes the satnav. If it doesn't, go to the "vehicle functions" menu and set it there. I agree, the procedure to turn off the destinaiton is a pain. I have only managed it by highlighting the destination (white circle next to it), selecting it and de-selecting the "guidance" option.
I hope that helps.
I hope that helps.
Thanks guys. I'll give that a go.
My Ride: '04 545i/6sp SilverGray/Beige
I hope that helps.
I hope that helps.
[snapback]56938[/snapback]
To cancel guidance altogether, go to the destinations list, select the current destination (there will be a a little arrow pointing to a dot (->0)) and uncheck the guidance checkbox.
I'm sure there are voice commands to do the exact same thing, but I haven't fully explored all of them.
-MrB
-MrB
The other thing you will discover is a pain with the Professional satnav (but bizarrely not the Business satnav, iirc) is there is no "route via" option. You can partially get around this by "loading up" multiple destinations using the "Add to destinations" and selecting each one subsequently.
A major oversight imo. Along with not being able to set road speeds.
Originally Posted by mrbelk' date='Nov 16 2004, 04:40 PM
If you have either steering wheel button programmed to "Repeat Last Nav Instruction," then pressing and holding for a second or two will mute the Nav instructions. ................
[snapback]56950[/snapback]
yes that is a key point and caught me out for quite a while doh!!! kept pressing button, damn woman (satnav not my other half!) just kept repeating the last instruction, then i figured out that to mute her you have to hold the button in like mrbelk says.
aqualibrium
07-21-2015 03:11 AM
