Satellite Prep
My Ride: 2005 MY 545i Sport Saloon. 2006 MY Alpina B3S Convertible. 2006 MY Brabus Smart 42 Cabrio. 2006 MY AM DB9 Coupe.
Welcome alex123
You don't say which country you're in. I assume USA, if so, my understanding is Satellite Prep refers to your Sat Radio that you have over there - is it called sirius 1 or something.
Loads of members from US here so they'll be able to help you a lot.
My Ride: E90 M3
Model Year: 2011
Originally Posted by Hobi' date='Nov 22 2004, 06:58 PM
Welcome alex123
You don't say which country you're in.? I assume USA, if so, my understanding is Satellite Prep refers to your Sat Radio that you have over there - is it called sirius 1 or something.
[snapback]59650[/snapback]
Oh, and welcome alex123!
My Ride: E60 "Stripper"
Now C6 "Stripper"
Invoice of 70 bucks? Come on BMW should just make Satellite Prep standard!
On 2005 E60's if Navi is not ordered you don't even get Navi Prep (Menu and voice buttons)! <_<
My 11/03 production had'em!
My Ride: E90 M3
Model Year: 2011
[snapback]59680[/snapback]
My Ride: E90 M3
Model Year: 2011
Originally Posted by alex123' date='Nov 22 2004, 09:05 PM
Is poosible to get aftermarket unit connected, I want to see if I can get one I can take home with me?
[snapback]59706[/snapback]
My Ride: G30 M550i
Model Year: 2018
Sirius also offers discounts after the first subscription. I think the first is around $12.95/mo and each additional is $7.95/mo (but that may be paying 12 months in advance).
Actually I have conducted extensive research and plan on ordering the parts to do my own retrofit tommorrow (I do not have the factory prep). The necessary parts for the wiring should be about $100.
You basically need one fiber optic cable and two antenna cables, the power plug is already present for the phone booster. The system in our car is a network. All you need to do is unplug the fiber optic cable going out of the TCU and going to the CD changer. The you connect the fiber optic cable that is purchased from the TCU to the Sirius unit. The fiber optic cable from the TCU to the CD changer is then attached from the output of the sirius unit to the CD changer. ergo you have a complete circle to the network. I am betting that a fiber optic wire exists and can be ordered from the TCU to Sirius unit (as this is part of the factory prep).
Then you run the two antenna wires to the shark fin into the trunk (also presumably part of the factory wiring kit) and use the power cable alread existing. If one of the connectors is wrong they can be ordered from BMW and changed.
THis will be my thanksgiving weekend project and will be coded on Monday assuming the wiring is succesful
I will update upon completion. Wish me luck!
