Sat Nav GPS location showing wrong country!! + NAV Retrofit PD
Old Oct 18, 2006 | 10:42 AM
HAMTT's Avatar
Thumbs up
Hey all! First Post!
I have just retrofitted NAV Professional into my '53 530D. I am in UK and the CCC unit came from Germany. All works fine EXCEPT:
1) Voice Activation is in German (will get resolved after software update booked in for next week)
2) The map shows me as being located in GERMANY, 700 miles from where I actually am! (the car/map shows location so the antenna is connected fine)
I have driven it around for a few hundred miles hoping it will calibrate but no such luck. (The map DVD was bought in UK). Any ideas cos I'm fumbled!!
P.S. Keep up the good work guys, I used alot of info from this board before doing my retrofit
P.P.S. I have attached FULL offiocial retrofit PDF for the Nav Professional. On my hunts I found odds n ends here and there but nothing as detailed as the one that is attached. Hope it helps the next person doing a retrofit!
File Type: pdf
Old Oct 19, 2006 | 01:28 AM
HAMTT's Avatar
anyone?
Kasmo
May 7, 2019 03:30 AM
rorschach76
Mar 19, 2015 08:59 AM
mrbelk
Oct 30, 2003 07:46 AM
