Runflat Warning Light
My Ride: AmethystGrau '03 530i
Originally Posted by dv8ed' post='497912' date='Nov 23 2007, 12:32 PM
i need help mighty experts... so i have a 2004 BMW E60 most likely with FTM. I have run flats if I replace them with non-run flats it's fine right? there's no sensors in my tire? i just have to reset via idrive. has anyone replaced run flats with non run flats.. everything ok?
My Ride: E90 M3
Model Year: 2011
On the 2007 US Spec E60 there are sensors to install. If you didn't install the metal valve sensors then the only way to turn off the alarm is to replace the standard valve stems with FTM (TPMS) sensors. The runflats or non-runflats should have nothing to do with the alarm going off. Once the sensors are installed, set the correct pressure on all four tires and then reset the alarm and calibrate it as instructed in the manual.
