Rough idle on 545i, dealership hasn't helped. Please help!
#51
I am having the same problem here! My check engine light came on for the third time! It goes off by itself after a few drives. Scanner read P0507. I cleaned both MAF and throttle body. Do you think cleaning or replacing the crankcase valve will solve this problem? Car has 75k miles
#53
Hi
I am having the exact same problems you were having on your 545i
I am getting the check engine light. Rough idle at times, and at times it runs like new. Autozone scanner says P0507. Did you ever fix this issue? If so what did you replace?
#54
My Ride: 2005 545i Sport
#55
I used to get CEL and "increased emissions" from time to time on my 545. Cleaned MAF, replaced CCV's (even though they looked not bad either), and it helped. Two years and no CEL again...
srogers535x
08-05-2015 08:48 AM
PelicanParts.com
07-23-2015 12:29 PM
