Right rear tail light stayed on after car turned off ?!?
My Ride: ActiveHybrid - fully tricked out
Model Year: 2013
So it's a little cold and mucky up here in Toronto (although a lot worse elsewhere).
I just drove back from Waterloo (a little less than 2 hours away). I parked in the garage, turned off the car and then got out (leaving the keys) to take the garbage down to the curb. A few minutes later I took out the key and locked the door. About 10 minutes later I came out (with more garbage) and noticed that the right rear tail-light was on. Nothing else was on. Only that one light. Hmmmm - sez I.
Being and IT guy, I figured that I should apply the usual fix - I restarted the car and let it run for a minute. Then I turned it off. All the lights went off. I'm assuming I'm ok for now but will keep an eye on it.
So - any idea of what happened? Stuck relay?
Thanks a bunch.
Stay warm.
Thanks a bunch.
Stay warm.
I think its normal I was installing my blue led side markers today and I forgot I did not have the key in and hit the stalk and ONLY the left tail and head light turned on. I had to restart the car? Maybe you hit the stalk by accident?
was the right angel eye on? The e60s have it built in where if u hit the blinker fully to signal right the right rear taillight and angel eye will stay one same goes for left.
Look in your owners manual. That is the "roadside parking" light option.
Roadside parking lamps, left or right*
You also enjoy the option of lighting up just one
side of your vehicle when parking:
Switching on
After parking the vehicle, press the lever up or
down beyond the resistance point, arrow 3.
Switching on
That is called Parking lights.
Model Year: 2013
Thanks folks.
That's why I'm a member - learn something new.
I never would have thought to look in the manual for something like "roadside parking lights". Especially since I've owned the car for over 5 years.
Thanks a bunch.
Thanks a bunch.
socale39
09-05-2023 08:30 AM
andymax
03-13-2015 10:51 AM
