Restraint System Failure (Passenger)
Old 11-04-2012, 06:31 PM
  #161
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
how can be a simple $200 fix??
i have the same problem like many of as
can u please tell as..how to fix this??
please and thx u
Old 11-04-2012, 06:45 PM
  #162
AchtungE60's Avatar
My Ride: E60 530i
Because that's the most you will pay for the software and tools to fix.
I have posted on this a long time ago and have fixed this for several members on this very board. Each member is different.
Old 11-04-2012, 08:22 PM
  #163
aw3964's Avatar
My Ride: 2006 530i
Swapnil Junnarkar
If it really is the seat mat sensor, your best bet is trying to have BMW NA reimburse you. I've seen it happen with VINs not listed for the recall, but it must be the exact same issue and only that issue for a full reimbursement. Also helps to note if you purchased that vehicle from BMW.
As for everyone else, as previously stated, please do not assume that warning means it is a seat mat issue. If you don't feel inclined to purchase the software, go to an indy shop and have them read and clear the code. Going to the dealer may only be worth it if you are positive the seat mat is the issue. Even if your VIN is listed, the error message could be due to something else and you are responsible for the $200. Some service managers don't emphasize this point (intentionally or not).
There are TONS of issues that can set off this light. I've had it traced back to the battery terminal before.
Old 11-04-2012, 11:43 PM
  #164
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
Originally Posted by aw3964
Swapnil Junnarkar
This is exactly what my issue was, faulty terminal cable when I received the restraint System Failure (Passenger) error.
Old 06-13-2013, 07:38 AM
  #165
minnesotaR6's Avatar
TTT. my 08 535i airbag / seatbelt restraint light just turned on!
My car doesnt fall in the seat sensor recall. but i was told i have a cable recall thats up.
Old 06-13-2013, 07:42 AM
  #166
mikegreen's Avatar
My Ride: 2004 530i 6-speed
Mine came on, was on for months.. I reset it with the ncsexpert+usb cable from ebay for $80... and its been off for a month now... glitch in the matrix..
ask them to clear the codes when you get your recall done.
Old 06-13-2013, 07:45 AM
  #167
i will have them do that! thanks!
do you know what the recall on teh cable is? i believe its the battery cable.
  #168
mikegreen's Avatar
Yeah, just a cable.. something about corrosion or something. I think it took them .5hrs on my car.
Old 06-13-2013, 09:08 AM
  #169
pcy
pcy's Avatar
Referenced battery cable recall has nothing to do with ABS malfunction.
Dealer will not simply reset ABS light (due to liability) without diagnosing and fixing the underlying issue.
ABS light can be triggered due to many issues - one of them is the seat mat sensor, other common failure is the BST (battery safety terminal or something like that). Only way to be sure is to run diagnostics and identify the code.
Old 06-13-2013, 09:21 AM
  #170
mikegreen's Avatar
PCY: your experience must be different than my dealer. They will simply reset a light and tell you to call when/if it comes back on.
Quick Reply: Restraint System Failure (Passenger)
